Project: Idle Hands (caseless computer) No linux, but new reset switch!!!
Discussion in 'Project Logs' started by Malvolio, 6 Jan 2004.
  1. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    YES! I have been waiting to see how long it would take you to resume modding this ghetto ass PC :D I cant wait to see what you do next. :thumb:
  2. Shinymod
    Shinymod What's a Dremel?
    20 Dec 2003
    omg that is ghetto-ass :D wp!
  3. Alienhead
    Alienhead What's a Dremel?
    14 Jun 2004
    I don't know why they call you idle hands. It takes me forever to get anything done. Some of the people here have too much time. I work 40 hours a week and do 12 units of college classes. so it may take me a while.
  4. Malvolio
    Malvolio .
    14 Dec 2003
    "Idle Hands" is the project name. For those whom don't get it, basically, when I started this project I didn't have anything better to do, my hands we're at "idle" as it we're. Thusly, this monstrosity was born. BTW, tomorrow (if I get time) I'll be buffing the psu on this thing and doing a few things to the wiring (as well as figuring out why the LED's don't light up properly).
  5. Hacker2B
    Hacker2B What's a Dremel?
    4 May 2004
    Looks good! :D :rock: :thumb:
    Hehe, i know what your talking about with the text lag. My computer is doing it right now, not bad but still... It's a P2 166MHz. That old 66MHz HP Vectra Multimedia PC in the corner is just asking to be modded. Maybe later.
  6. Malvolio
    Malvolio .
    14 Dec 2003
    Welp, I decided it was time for a change. So, insted of polishing this thing up today like I was going to, I'm going to actualy format the hdd and install..... Linux! :D My first serious try at it. I'm following the "Lo-Fat Apache/FTP server using Slackware" guide located Here Wish me luck (system's booting now via boot disks...)
  7. Malvolio
    Malvolio .
    14 Dec 2003
    No comment? :eyebrow: Umm, ok, intersting....... And I thought I was weird... Anyway, stupid thing is erroring out now.... The second install floppy disk isn't loading (giving me cnc or whatever errors like crazy).... Ah well, I'll get it figured out.
    [EDIT] OK, not CNC errors, it's "CRC". Heres a bit of the error I'm getting:
    Loading install.2 floppy into RAM disk... floppy0: data CRC error: track 0, head 0, sector 18, size 2
    It just keeps going like that for like 10ish lines. And it does this with 2 different disks.... So I'll try another one, and hopefuly that works...[/EDIT]
  8. PsychoI3oy
    PsychoI3oy Minimodder
    13 Apr 2004
    try download whatever image you used to make the floppies again. crc is an error checking method, basically it says your floppy image ain't what it's supposed to be.
  9. Malvolio
    Malvolio .
    14 Dec 2003
    The floppy image came off the slackware install CD that I have. But trying the third floppy seemed to fix the problem, and it's installing now :D Thanks just the same though :thumb:
  10. PsychoI3oy
    13 Apr 2004
    noprob, have fun
  11. robotguy9000
    robotguy9000 What's a Dremel?
    3 Jun 2004
    lol, heres my opinion
    this mod violates robot's modding rule #3-
    Never do a mod that you wont use,
    and it also violates rule #1
    If you're gonna make a mod, put time into it and make it look good
    BUT THATS WHAT MAKES THIS THING FREAKING AWESOME!!!!!
  12. Malvolio
    Malvolio .
    14 Dec 2003
    OK, fistly, I am not violating the rule, I'm throwing a server onto it, as I do intend to use it as a server :baby:. Secondly, I have put time into it, and it does look good :worried:. Thridly, why yes, it is freaking awesome :D :p
  13. Malvolio
    Malvolio .
    14 Dec 2003
    Yay! I failed at my first real attempt at linux :D
    Thats what I get at boot up. It won't go any further than that. I'm figuring reinstall, or just go back to 95b....
  14. Xipher
    Xipher What's a Dremel?
    25 Apr 2004
    Ahh, the evil LI 99 99 99 .. .. Error.
    What Distro are you using?
  15. Malvolio
    Malvolio .
    14 Dec 2003
    Slackware 9.1, or 8.1, or 9.0, or...... Not 100% sure :D All's I know is it's slackware, and was the most reacent when I dl'ed it. Anyway, I was told it was a problem with the loader program, maybe I've screwed up lilio or something. I'm going to try reconfigurating lilio and seeing if that works.
  16. Xipher
    25 Apr 2004
    Yea, its a Lilo problem, and I have had it before. Did you use a CD or Floppy to boot into the installer? If you used the CD, you can use the info at its boot prompt to get into your already installed setup, and all you should need to do is maybe make some changes to /etc/lilo.conf and rerun lilo.
  17. Malvolio
    Malvolio .
    14 Dec 2003
    This particular system was built before CD-ROMs became "main stream". IE, the only way I could install was via floppy :p I did actualy have a problem installing lilio though. When I entered in the correct info and followed the guide exactly, it said that it couldn't install to the mbr. Then I messed arround with it and magically it installed :D But as it would seem, I messed something up lol. Ah well, live and learn.
    [EDIT] Oh, if it helps, I used the "old_cd.i" kernal as the basic.i one didn't take [/EDIT]
  18. Xipher
    25 Apr 2004
    one thing you might try is in the BIOS configuration, staticly setup the Hard disks info, and make sure you don't use the lba32 option in the config. also make sure you set at least one partion with the bootable flag in fdisk. if you used cfdisk it will warn about this any way. normally thats not a problem, but its something worth looking into. you might try letting slackware come up with a simple lilo conf automaticly, as it tends to work fine, but don't use the special vga options for higher res, as it probably won't work on that old of hardware.
  19. Malvolio
    Malvolio .
    14 Dec 2003
    Thanks so much for the help :thumb: Anyway, I'm in the setup bit again for slackware, booted up via the setup floppy's, and I've run into a problem. Theres no option to setup/edit lilio... :wallbash: Stupid thing. Anyway, I'm going to reboot and try the bios bit now, I'm sure it's setup correctly, but I'll take a wack at it anyway.
    [EDIT] YAY! My kernal paniced!!! Whatever that means anyway :worried: All's I know is, the system isn't quite locked up, and the keyboard numlock/capslock/functionlock buttons are flashing in some alien pattern. I think my computers speaking in binary to me :worried: [/EDIT]
  20. Chrizzle
    Chrizzle What's a Dremel?
    6 May 2004
    So, any plans for overclocking?
