Case Mod - Complete PROJECT ISOLATION (modded Cooler Master MasterCase 5 Maker)
Discussion in 'Project Logs' started by ciobanulx, 30 Apr 2016.
  1. ciobanulx
    ciobanulx Modder / Watercooler
    24 Jul 2014
    Thanks a lot, I'm really happy with the finish!
    And yea clear coating it seems to seal the deal, the case is just as strong now that it's all rusted :p
  2. ciobanulx
    24 Jul 2014
    Hi guys,
    Here's the case all reassembled and looking as awesome as ever! I'm really happy with the result and it goes perfectly with the theme.
    Still some effects to add over the rusted paint for a more Dead Space look and some things to build around the top and front panels.
    Let me know what you guys think.
    Thanks for checking it out and stay tuned for more!
    Cheers,
    Alex
  3. ciobanulx
    24 Jul 2014
    Hi guys,
    Sorry for the lack of updates on this build. I've been quite sick over the last week and haven't had a chance to post more updates.
    The race is now on to finish this build by the 12th of June. That's Sunday this week as that's when the Cooler Master CaseMod World Series ends.
    Here is the work I've done for the top and front panel.
    If you haven't guessed it by now the front panel will have Isaac Clarke's helmet from the original Dead Space game mounted to it. It should look pretty nice if done right!
    Let's have a look at the progress!
    First up the helmet pieces. Started of with a piece of 2mm black acrylic. Measured and drew out the shape by hand.
    If you can't see it yet, you will be the end of this update.
    Next up were pieces for the top panel to work around the tube. Just designed a random pattern from scratch that I thought would look good and everything was cut by hand with my Dremel Moto-Saw.
    Helmet pieces all cut too
    I went ahead and bent the acrylic pieces to shape and mounted with other straight pieces to form the overall helmet design.
    The way I bent them was with a sheet of thin aluminium that was used to measure the shape of the front panel and then taped up to hold that particular shape. Once done, the acrylic pieces for the helmet were placed in the middle individually and heated up until they took the shape of the aluminium sheet. Unfortunately I was too into it at the time and forgot to take pics.
    You can see it coming together.
    More work on the top panel. Mounting the pieces together.
    And here they are both on the case.
    More pics from the next day.
    And lets not forget the finishing touches on the helmet
    Let me know what you guys think! These will also be rusted which you will see once done.
    Sorry if the quality of these images wasn't too good. They were all from my phone.
    Cheers,
    Alex
  4. arduum
    arduum Minimodder
    10 Mar 2015
  5. ciobanulx
    24 Jul 2014
    Bit more progress! Starting to get hardware in the case!
    Also yesterday I forgot to mention that the full specs have been updated in the first post!
    Here they are:
    Case - Cooler Master MasterCase 5 Maker
    Motherboard - ASUS Maximus VIII Extreme Assembly
    CPU - Intel i7 6700K
    Memory - 4 x 4GB Avexir ROG Certified Red Tesla 2400Mhz DDR4
    GPU - 2 x ASUS STRIX GTX 980
    SSD - 2 x Kingston HyperX Fury 240GB SSDs
    PSU - Cooler Master V1000
    Cables - CableMod Fully Custom Individually Sleeved Cables + MercoMods Custom Braided Extensions
    LEDs - CableMod Magnetic RGB LED Strip
    Radiators - Bitspower Leviathan Slim 240 Radiator, Bitspower Leviathan Xtreme 360 Radiator
    Fans - CoolerMaster JetFlo 120mm Red and White LED fans
    Pump - Laing D5 with Black Bitspower MOD Package - Pump Top + Casing
    Reservoir - Bitspower D5 Top Upgrade Kit 150 with Cascade Tube Effect
    Fittings - PrimoChill Revolver SX Matte Black + Various Bitspower Carbon Black angle fittings and extensions
    Tubing - PrimoChill Copper Tubing
    CPU Block - Bitspower Summit EF
    GPU Block - 2 x Bitspower VG-NGTX980ADIIS
    Thanks for checking it out!
    Cheers,
    Alex
  6. ciobanulx
    24 Jul 2014
    Hi guys!
    Here's the helmet nearly finished! Just some more minor details that will be added.
    The light is only as an example from my phone, it will be better once on the build.
    Also a quick rusty PSU mod. I didn't want to ruin the PSU so I used vinyl and rusted that. Then simply applied to the sides of the PSU and came out pretty well.
    [​IMG].
    Cheers,
    Alex
  7. cucmag
    cucmag What's a Dremel?
    31 May 2014
    nice work :thumb:
  8. ciobanulx
    24 Jul 2014
    Thanks a lot :D
  9. ciobanulx
    24 Jul 2014
    Hi guys,
    A quick showcase of the glorious ASUS Maximus VIII EXTREME ASSEMBLY motherboard!
    Thanks for checking it out! On the final stretch!
    Cheers,
    Alex
  10. ciobanulx
    24 Jul 2014
    Hi guys,
    Getting closer to finishing the build!
    Received the cables from CableMod and also did a special paint job on the reservoirs which wasn't really hard to do!
    Here's the reservoir!
    And more components going in the case, starting to take shape!
    Cable management! The reason they are like that so far is that there will be some different extensions for the 24pin and GPU cables which will hopefully arrive in time from Merco Mods. As the build needs to be ready by Sunday, not sure if they will be here in time unfortunately.
    You can also see a sneak peak at the finished top panel here.
    Let me know what you guys think! Not too long now, will have to rush through a few things for the build log in order to upload everything by Sunday.
    Stay tuned for more.
    Cheers,
    Alex
  11. ciobanulx
    24 Jul 2014
    Hi guys,
    Here are the final pieces going in the build!
    Awesome new Primochill SX Revolver fittings! I'm loving the new finish Primochill now offer on their fittings, these are the matte black ones and will go nicely with the build.
    Also some incredible looking waterblocks from Bitspower! These have been installed on the ASUS STRIX GTX 980. Two of them going in the build.
    Finally some very sexy looking memory, the AVEXIR Raiden Series Red Tesla ROG Certified memory!
    Looking very nice in the system with a sneak peak at the copper tubing!
    Final pics coming up!
    Cheers,
    Alex
  12. ciobanulx
    24 Jul 2014
    Okay, here we go! Final pics!
    I apologise from the start however there are a lot of pics, just wanted to make sure I cover everything!
    Thanks a lot for checking it out guys and hope you enjoyed this build log! There are still things I would like to add to the build and they will be however for the time being the build is finished!
    I should have a showcase video up for it in the next couple of days as well!
    Cheers,
    Alex
  13. ciobanulx
    24 Jul 2014
    Hi guys,
    I have a few more pics to share. The cables from Merco Mods arrived a few days after the build was due for submission into the Cooler Maste CaseMod World Series competition unfortunately. I've put them in now and I gotta say they look amazing and the colours work well with the theme.
    Also VOTING for the competition is now live, check it out HERE.
    If you've enjoyed this build log and like how the build turned out please leave a vote. It only takes a few seconds to vote using Facebook at the link above. While you are there check out all the other builds as well.
    If I'm killing anyone's internet or mobile data with all these pics, I apologise but I always try to have a nice quality build log.
    Again, thanks a lot for checking out my build! I should have a video coming up in the next few days. I just need to edit it.
    Leave a vote HERE.
    Cheers,
    Alex
  14. hovek
    hovek “Can’t or won’t?” Sterling Archer
    23 Jan 2014
    Turned out really nice man. Cables look great!
    Have you thought about a way to drain the system if necessary?
  15. ciobanulx
    24 Jul 2014
    Thanks a lot man :)
    For draining, yea just undo the tube in front of the pump and start draining through there. This is usually what I do, I never install a drain port anymore :p
  16. rrmitko
    rrmitko Minimodder
    14 Jun 2014
    Another masterpeace :clap:.My vote is your's Alex :thumb:
  17. ciobanulx
    24 Jul 2014
    Hehe thanks a lot mate :D
