Case Mod - In Progress project:K.I.D (disaster 28/12/07)
Discussion in 'Project Logs' started by khanage0, 2 Sep 2007.
  1. ComputerKing
    8 Sep 2006
    WOW!~ this is KICKASS! DAM I can't explain! This is awsome. Well done, Can't wait to see more.
    Good luck.
  2. khanage0
    khanage0 Minimodder
    2 Sep 2007
    thanks for the comments CK really appreciate the possitive comments ive been getting.
    hoping to get more done on it real soon but with work an a family finding times hard.really wanna start on the side for the phase this week,just found out a mate has got me some metal from work to start it but dunno weither its gonna be any good yet,for the side anyway
  3. ComputerKing
    8 Sep 2006
    Can't wait to see that ;) :rock:
  4. khanage0
    khanage0 Minimodder
    2 Sep 2007
    made a start on the side panel for the phase today,still got to do alot of filling an sanding to get the finish im after but its a start
    hole cut in the panel
    pipe and angled alluminiumglued into place to form the basic shape
    first layer of filler
    second layer of filler sanded back to form the rough shape
    primed up to highlight the parts that need attention and fitted to the case,still gotta make a frame for the inside of the panel to bring it out flush with the rest of the case,but im liking it so far:p
    what ya think?????
  5. Multiplectic
    Multiplectic His Stigness
    4 Sep 2007
    Great fiber work. :thumb:
    And the name... what do you think of "K-Freezer"?
    You already have the "K", so why wouldn't you use it?
    Keep on modding! :dremel:
  6. cire9753
    cire9753 What's a Dremel?
    16 Aug 2006
    great project, cant wait to see more :dremel:
  7. khanage0
    khanage0 Minimodder
    2 Sep 2007
    started to make a false floor from aluminium for the case today to hide the wires from the phase to the power switch an stuff so you dont see a load of trailing wires and to cover the big hole i had to cut in the bottom of the case to allow the evap head through,just in the process of polishing it up at the mo.gonna be raised of the bottom about 10mm on spacers
    pretty much finished the panel for the phase as well just gotta fill the existing screw holes an drill new ones so they look more asthetically pleasing,will post pics of it when its all done.
  8. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    looking great and awesome bondo work
  9. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    Lookin' good. Man, this thing must weigh a ton.
  10. khanage0
    khanage0 Minimodder
    2 Sep 2007
    it does mate:sigh:but at least im still gonna have it if i ever get burgled...lol
    thanks for the comments guys :D
  11. E.E.L. Ambiense
    26 Jul 2007
    At least it'll have it's own form of OnStar or something...you just follow the dragmarks for theft recovery. :D
  12. khanage0
    khanage0 Minimodder
    2 Sep 2007
  13. Guest-23315
    Guest-23315 Guest
    I'm subscribed..
    How about : Project: Frozen Dragon
  14. khanage0
    khanage0 Minimodder
    2 Sep 2007
    liking that mate "frozen dragon" really wanna try an get the K or khanage/khan in the name as well,mainly caus of the K i cut in the side only cut the K in caus my gaming names khanage an didnt wanna plain square or rectangal window was trying to be a bit different/original.
    really flattered that youve subscibed as well mate,just hope it all goes well being my first project apart from the odd window,it all started as an experiment for an idea i had an i was real pleased with the way the first bit came out an just kept going,havent really got a plan made up for it at all but did check all my hardware was gonna fit,its tight but does fit:Dso any ideas you think may work let me know im always up for new ideas
  15. Guest-23315
    Guest-23315 Guest
    ^^ cheers.
    You've allready gotten ahold of some damn good fibre-glass skills.
  16. E.E.L. Ambiense
    26 Jul 2007
    If it were TEC-based, the Chief-TEC works. Kinda writes itself. :hehe: But I'm out of ideas for naming. I like this project regardless of name.
  17. dacust
    dacust What's a Dremel?
    10 Mar 2007
    Maybe Frozen Karnage? Frozen Kharnage? Maybe that's dumb, but it just came to mind.
  18. khanage0
    khanage0 Minimodder
    2 Sep 2007
    been thinking maybe i'll call it project:K.I.D (khans icy dragon)
    what ya think? if i do change the name is there any way i can change the name of the thread?
  19. Guest-23315
    Guest-23315 Guest
    Edit the title in the first post.
  20. khanage0
    khanage0 Minimodder
    2 Sep 2007
    painted the inside of the case satin black,not alot of its gonna be seen but wanted it done anyway
    found the colour i think im gonna do the outside so tested it on the case
    what ya think?decided to go with just a gloss blue rather than a metalic mainly because it seems alot easier to get a deep shine on when polished and i think it will suit the case better.
    not alot to show i know but works gone mental at the mo hoping to get a bit done the weekend between work an family.
