Here we go some pictures on my case it is 30x30x20 cm has water cooling built from the bottom to the top by my self. It is a xp 1800 1,53ghz @ 1,714 ghz on a ASUS A7V 333 motherboard, Geforce 2 Ti 500, 256mb pc2700 ddr ram and got one 4,3 gb and one 80 gb harddrive. It also got a external ASUS burner 40x12x48x, 21" screen, microsfot intelli explorer V. 3 mouse and a Microsoft Naturall Pro keyboard. Bigger Versions @ http://w1.176.telia.com/~u17608630/Burk/ It is just a beta planning to build a new one soon that one also in plexiglas but thinking of getting a window from xport1 to use as side.
sooo did you have to stomp on the inards to get them to fit? gj dude especially on the w/c'in in such a small space
thanks... this is as small as i getts with a good watercooling and a ATX std motherboard... surly there are some small changes that could resolve in a even smaller case i will begin drawing on the new improved case soon dont know if it will be with bent corners or like this glued... hmm Thanks for the possitiv replies
Where's the side panel? I think with the inards so well packed like that (well done on that btw) it's better hide them with a sleek exterior.
I havent had time to cut the side panel.. vill get on that as soon as i get time it is going to be in plexi glas.. thinking of putting sun film on it so it is a little "stealthy"
awesome d00d! few Qs though A)Why is the fluid so green? food coloring? looks cool. B) I know the rad looks bigger b/c its such a small pc but why did u choose such a large rad?
why does the green... stuff... look so THICK? looks weird! otherwise nice one cramming all that gubbins in such a small space!
