Project Management Tools: Updated - TESTING NOW! See last post
Discussion in 'Software' started by DougEdey, 2 Sep 2007.
  1. DougEdey
    5 Jul 2005
    Nothing?
  2. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    i'll have a go when i get back from work, be patient my padawan :D
    disclaimer: the above is not condescending, but a mere attempt at sounding funny. ah well.
  3. Arthur2Sheds
    Arthur2Sheds Jackson
    19 May 2003
    All right, I've had a chance to play with it a bit, and here's what I've noticed.
    1. Nice, simple design.
    2. Intuitive buttons.
    3. Customers can create managers.
    4. 'Show all delays' doesn't work.
    5. Newly created customer, TestCustomer, doesn't display under the New Project screen's Customer drop-down box.
    6. What's the difference between 'Tasks' and 'Activities'?
    All in all, I think you're off to a good start. No small task you've undertaken here, that's for sure!
  4. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    thought i would have a little look after being forced (against my will) to use ms project. And have to say from what ive used its a much nicer program to use. do you intend to release it once your project is complete?
    edit: ie7 (forced again) reports an error on the user admin page
    Code:
    line 146
    char 2
    error Unterminated string constant
    code 0
  5. DougEdey
    5 Jul 2005
    Thanks for the responses guys, I won't be able to act on them or respond properly untill Friday afternoon/evening though.
  6. DougEdey
    5 Jul 2005
    Sorry about the delay, just re-checked everything
    1&2: Thanks, that's what I wanted :)
    3. This shouldn't happen, checked everything and I think it's because you created TestCustomer as a Manager :p
    4. Yup, I knew this, I've held back on that for the moment as it's technically not required for my FYP. It'll be worked on if I have the time, but I still have to finish my report and write user Documentation.
    5. See 3, I've changed them to Customer and they show up.
    6. I'm changing from tasks to activities as other management tools use activities as they use it to implement meetings as well, which I've adopted.
  7. Arthur2Sheds
    19 May 2003
    So basically it works fine and I'm just a dork?
    Well, I'd rather that than you having to rebuild everything.
    Props to you - as simple as it is, I could never have built that.
  8. DougEdey
    5 Jul 2005
    Nah, creating someone wasn't working right, it wouldn't load the confirmation and the editing and deleting was also broken, fixed them tho :p
    Thanks for the support btw, just got 2 weeks to sort out documentation then hand it in :)
  9. Millusdk
    Millusdk What's a Dremel?
    27 Jan 2008
    The calendar seems to be broken
  10. DougEdey
    5 Jul 2005
    Not sure what you mean by that. Could you give more detail?
