Scratch Build – In Progress Project: ? (Mario Cube)
Discussion in 'Project Logs' started by TAKTAK, 16 Feb 2010.
  1. Cheapskate
    13 May 2007
    There's also the option of (carefully) stripping the psu, and re-casing it to suit your needs.
    -Although I don't think that's an option with the BeQuiet! psu.
  2. TAKTAK
    TAKTAK I R Pandi
    2 Jul 2008
    Listan have actually done a decent job in terms of maximising space in the SFX formfactor, so it wouldn't really save much for this PSU :(
    I'm still waiting for the fail-boat from China, so in the mean time i grabbed some braid from Chilled PC so i can have a mess around.
    The other day i just chucked a bit of heatshrink on the power connector on the PicoPSU:
    Old school hair-dryer of pain:
    Looks crappy, but it insulates the terminals :)
    Thought i'd have a pop at a SATA data cable tonight, i only have the moulded connector though so i had to use a larger ID heatshrink (12.7mm) (the braid isn't too bad as it expands and then pulls taught over the cable)
    Any way, enough jibber-jabber:
    The boring run of the mill red defacto SATA data:
    This is the 10mm - 3/8" whatever size you want to call it, that is black and red with a dense weave:
    Cut the appropriate size and melted the end to stop it splaying out:
    Pushed onto the cable:
    Roughly cut some heatshrink:
    Heat with a lighter for much faster results than a hair-dryer:
    Then i added a cable-tie just to keep it held together (on the off chance):
    Leaving me with:
  3. Quavr
    Quavr Minimodder
    3 Jul 2009
    Great looking mod, you've got a lot of kit in that small case :thumb:
    The cable looks nicely sleeved, I especially love the colours you used for the sleeving, never seen any like that before, butthen again I havn't looked very hard:rock:
