Hello every one here i come with new mods the work in a PC case with the idea that i get it from the airbrush tricks videos i will show off the work with the case hope you all like it for more info go to www.modscases.com this the case i am working with Ultra M923 ATX Black Full Tower Case first i take the front of the case out and i take every thing out and i just left the frame here i add fabric i was going to make it with fiberglass but i don't have the place to work in after any time of sanding and falling it with auto faller i paint it to black this from in side after i add the 3 fans into the front i pant them from black to gray come back for more pic will be add thanks for looking
Good idea, but that frontpanel looks quite bumpy. It needs to be sanded down again, and given bondo a few times I spot some holes and bums here and there. Other than that, good work
hello you are right and thanks for looking i have done a lot of of work on it here some update i add the rope in all of the case after painting it with gray after i take the rope out i work with the airbrush adding the black line that rope left more pic will be add with add the affect thanks for looking
