Case Mod - In Progress Project: Miracleman XB - Done?
Discussion in 'Project Logs' started by TheGreatSatan, 28 Feb 2013.
  1. TheGreatSatan
    TheGreatSatan Member for 17 years!
    5 Aug 2005
    This mod is inspired by the incredible series written by Alan Moore back in 1982. Miracleman was similar to DC's Shazam. He was a young reporter who was given great super powers through atomic energy. Speking the word ATOMIC backwards: written as "KIMOTA" is what transformed him into Mircleman.
    The series gets very dark. It touches on mass genocide by super heroes and the idea that we may not be alone in this universe.
    The victim case is the Cooler Master HAF XB.
    But first it needs to be stripped to the bone
    Then blasted with a bright sail boat blue
    Bottom
    and top
    The front panel metal mesh will be blue too
  2. IamJudd
    IamJudd Multimodder
    30 Oct 2011
    Ooh... I like this!
  3. spolsh
    spolsh Multimodder
    4 Feb 2012
    Going to follow this one with real interest as I've recently acquired one of these cases. Only change I've made to mine though was to fit a 200mm fan in the roof.
    Did you mask off the rubber feet, if not, has the paint taken to the rubber okay, or had any reaction ?
    I'm guessing you're going to replace the CoolerMaster badge with a MiracleMan logo ?
  4. TheGreatSatan
    5 Aug 2005
    forgot to mask 'em, but they seem fine. No on the badge
  5. TheGreatSatan
    5 Aug 2005
    I wanted to do two 120mm fans on each side, but they won't fit
    So I'll do 92mm fans instead (I'm not using the grills, they're just for reference)
    Time for my hole saw
    I cut two fan holes and the mesh on each side for windows
    I just want to see how it looks, so I put the mesh back on. Yep, that looks stupid!
    That odd looking honeycomb looks even worse
    So it has got to go!
    Now it's Red!
    And so is the PSU shroud
    And just about anything that's not already blue.
  6. sparkyboy22
    sparkyboy22 Web Tinkerer
    3 May 2010
    I suggested orange and that red isn't all that far away.
  7. hampurista
    hampurista What's a Dremel?
    21 Jan 2013
    Comic theme? Check. Alan Moore? Check. Somewhat ugly case out of the shelf that must be modded? Check. Subscribed? Check.
  8. TheGreatSatan
    5 Aug 2005
    While the red paint dries we go dress up the blue chasis. First I put the hot swap bay PCB back in
    On to the cooling. The Cooler Master XB only comes with two 120mm intake fans, but I want 140's instead
    I'll be using Aerocool Blue LED Sharks
    And I put the tooless clips back on
    I really don't want to see the stickers through the fans through the mesh, so I'm taking them off
    I put the motherboard tray back in
    And then a rear 120mm Blue LED exhaust fan
    There's also another two 80mm Blue LED fans going on the back by the drive bays
    Lastly, the slots cover go back in.
    Next time we'll look at the side panels
  9. jrs77
    jrs77 Modder
    17 Feb 2006
    With the grills left in place the fans in the rear of the case will produce an awful lot of noise. It's allways the first thing to do, to cut out the honeycomb there.
    Nice colourscheme tho ;)
  10. TheGreatSatan
    5 Aug 2005
    I'll address that, with an inline resistor
  11. TheGreatSatan
    5 Aug 2005
    I put the top piece is dry
    And so is the PSU cover
    The drive bay covers are done as well
    Now I have to paint the side panels
  12. YearZero
    YearZero What's a Dremel?
    16 Aug 2009
    Wow, these colors are really going to make the case stand out in a crowd. Keep it up!
  13. TheGreatSatan
    5 Aug 2005
    It took 3 strip downs all the way to the metal for it finally to stick. This was a really annoying process, but it's finally done
    Now it's time for some custom fan grills
  14. Phame
    Phame COOOOFFFFEEEEE
    17 Sep 2012
    Im getting me one of these cases. Looks good dude.. :D
  15. TheGreatSatan
    5 Aug 2005
    Now that the sides are dry I put the plastic handles back on
  16. TheGreatSatan
    5 Aug 2005
    I'm using an all plexi top
    And using rivets to hold it in place. I put tape over the tip of the rivet gun so I don't accidentally scratch the paint
    I got this custom applique from CrazyPC (I still need to remove the bubbles)
    KIMOTA!
  17. TheGreatSatan
    5 Aug 2005
    I had custom Miracleman logos cut out of aluminum by Rapid Creek Cutters
    I'll be using a regular 92mm grill as the base
    Next I give everything a couple of coats of red
    Looks awesome
    I'm gonna go with just two screws or each fan
    Then a Bondo/epoxy to bond them together.
  18. TheGreatSatan
    5 Aug 2005
    All I need now is the side panel glass
    Nearing the end
  19. Phame
    17 Sep 2012
    This is sweet dude.. Gave me some ideas for mine, it's just in the corner in its box..
    I love the colours and placement of those fans!!
    :D
  20. TheGreatSatan
    5 Aug 2005
    I still needed to add the glass on the side panels
    I'd actually like to do a couple more things, but there are time restrictions I'm under by the person getting the case. So, I am done.....I guess
