Project: mk.V (a UV circuitry theme) -=[FINISHED]=-
Discussion in 'Project Logs' started by Captain Slug, 29 Oct 2004.
  1. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    Well, as it happens on a semi-yearly basis my computing needs have yet again changed from what they were. Last year's "ideal" usage parameters spawned the creation of my FlameCube. This year it's spurring me in the direction of a machine that's slightly larger, and more versatile.
    Proposed Specs
    Adjustable ducted air cooling
    Pentium 2.4c
    512mb pc2700 (maybe in dual, not sure yet)
    80gb 7200RPM SATA HDD
    GeForce FX 5900XT 128mb
    ASRock "P4I65GV" i865GV Motherboard
    Lite-On Black 52x24x52x16 Combo drive
    2 120mm fans on rheobus control
    UV and Red LED illumination
    Theme and/or Aesthetic focus
    UV circuitry effects. Blue, Black, and Aluminum material color set.
    This project is going to progress rather slowly between now and January since I'm a full time student now. But I have everything planned out and setup in stages which should prevent me from rushing through any part of the process.
    This will be my first Project Log ever with enough pictures to demonstrate what it is that I'm doing. :-/
  2. kenco_uk
    28 Nov 2003
    Should look tres nice! :thumb:
  3. Nexxo
    23 Oct 2001
    What? Slower than mine? :D
    Clever idea, reproducing a Soldam clone. Cheaper and better fit you your individual needs.
  4. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    lmao, no one can go as slow as you ;).
  5. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    This should be an interesting project to keep my eye on. If you can make it look as you showed in the photoshop mock-up you have got some mad skills.
  6. Xhiz
    Xhiz What's a Dremel?
    28 Oct 2004
    Very nice cases to mod
    Good luck m8 and looking forward to your pictures :thumb:
  7. Captain Slug
    25 Nov 2001
    The lack of available quality micro-ATX cases can be frustrating. but I should be able to make what I want with what I have available.
  8. Captain Slug
    25 Nov 2001
    Well, this project has been turned on it's head. After shuffling parts around in CAD and generally not liking any of my results from 3 days of research I basically became frustrated. Then I realized that I STILL have a perfectly good, sturdy all-aluminum case under my bed which I have since been unsuccessful at selling.
    So, my trusty old Rackmount case is going to get a serious face lift. The parts I have already ordered will have plenty of room to play around in this thing and it's giving me a million more ideas. Plus I won't have any of the problems I was having with the PC-42 layout.
    Planned
    - Wire Junction Box (changed)
    + Custom-made plug wire separators
    + Rheobus / Front-Panel monitor
    + All ducted cooling
    + Molex replacements
    - Stealthed ATX and P4 Power (changed)
  9. Captain Slug
    25 Nov 2001
    Arg! Well, after tallying up expenses I decided it would be more cost effective to change some of my plans. However, the change will make the time involved much shorter, and the end result will be more uniform. In other words I'm going to be buying this power supply:
    The color scheme is now down to just Black with silver accents. The lighting colors will be UV and red LEDs as before, but with more intensity and front access interchangability between the two.
    I may also decide to incoorporate a 5.4" LCD monitor which I have, up until now, not had a specific use for.
    this not not go as slowly as I had anticipated. But it will still be finished sometime around Christmas.
  10. Captain Slug
    25 Nov 2001
    And chaos ensues...
    the case has two bay modules. The top module will be used for drives and maybe and LCD. The bottom module wil be and intake duct for the video card cooling.
    The center support beam for the case will act as a support spine for the custom plug wire seperators that I'll be making. That will allow me to arrainge the cables in an orderly and aesthetically pleasing manner.
    This is only the beginning.
  11. Captain Slug
    25 Nov 2001
    I have accomplished theoretical progression and I now have an all-encompassing part list with which I will be ordering supplies. I've decided to go without the 5.4-inch LCD since it would take up too much front panel space, plus I simply don't have any use for it. Here are a few design concepts I'm working with.
    I do not want to try and hide wires, this is mainly due to the layout of the case and how it prevents me from routing wires behind the motherboard. So, since it won't be too difficult to keep the look of the cables uniform, I will need a means of organizing them neatly and directly. Enter the Plug Wire Seperators.
    But, I can't find any that aren't ridiculously priced or made for mounting in the way I need them to. Since I have a wealth of power tools and scrap plastic at my disposal, I will be making a custom set of my own in whatever colors and thicknesses I want. Having the wires in plain view will be no problem considering they will look so good.
    Power Cables
    Fan power and Motherboard frontpanel cables
    IDE
    Cables can be beautiful, if they're not chaotic and tangled.
    Also, I will be adding faceplates to cover the motherboard. They will "float" above the motherboard on long bolts and nylon spaces. Not only will it look strange, but it will provide both alot of light reflection, and a useful secondary surface for mounting the custom plug wire seperators that I will be using to route fan and cold cathode power cables. Here's a doodle I made over the board layout from the manual which should give you some idea of what it will look like.
    The blue sheet will be UV reactive blue acrylic, and the dark sheet will be smoke-tinted polycarbonate.
    That's all I have to contribute at the moment. Some time tomorrow I'll give a preview of the aesthetically weird cooling duct thingy I have planned.
  12. Captain Slug
    25 Nov 2001
    I'm building a gasket to mount the 120mm fan I plan to use into the lower drive bay of the case. This will suck air through the dust filters in the front of the case, and force the air directly onto the video card heatsink.
    The duct will be setup as a sandwhich of these parts
    80mm clear fan (blades removed)
    [​IMG] 4" Clear PVC duct hose
    [​IMG] (blades removed)
    [​IMG] 80mm to 120mm UV reactive fan adapter
    [​IMG] Delta WFB1212M, 72CFM 34dBa, rheobus adjustable
    The framing wire of the duct will be removed and then replaced with a few uv reactive wires to make the whole duct glow. It should end up looking like this
    The gutted clear 80mm fan at the end of the duct will mount near the video card on the support rail in the middle of the case. The duct will not only help to channel the air flow into a single point, but it will also help to muffle the sound of the fans inside the case.
    I could have gone wil a UV reactive 120mm fan, but I already have these fans and their noise level is pleasant enough, even on full power.
  13. Captain Slug
    25 Nov 2001
    Here's the logo for the case
    And how I might apply it to the board covers.
  14. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    Looking pretty cool, I like the idea for the plexi over the mb, you could do some neat tricks with lighting there, can't wait for some more updates
  15. Captain Slug
    25 Nov 2001
    Placing all orders now so that (hopefully) I'll have some goodies to play with over this weekend.
    While sitting in an extremely boring lecture I managed to plan out all of the cable routes for various parts and I designed the plug wire seperators accordingly.
    I'll keep that a secret for now to keep you guessing. :)
  16. Captain Slug
    25 Nov 2001
    Hooray! The first order arrived from Mcmaster. I got...
    My clear PVC duct, which I need to trim a 4 inch peice off of. Will be wrapped in UV reactive wire.
    My miniature aluminum toggle switches with tip-mounted red LEDs. Each LED will display the activity level of a single hard drive by means of an IDE cable modification. Plus they're shiny. :D
    I still need to go buy the power LED from radioshack
    And my blue UV reactive acrylic. Which i can't do anything with until my motherboard arrives.
  17. greywolf
    greywolf What's a Dremel?
    15 Oct 2004
    I really like those toggle switches! Were did you find them?
    Case is coming along nicely!
  18. Captain Slug
    25 Nov 2001
    For US Buyers: I bought mine from McMaster. Simply go there and search for "toggle switch", then select page 801. It's the last switch entry on the list and it comes in SPDT and DPDT with ON-ON or ON-OFF-ON varieties. You can also order them with GREEN LEDs (but not blue).
    For UK buyers: Maplin has a similar toggle switch, but with a chrome finish.
    I prefer the finish on the mcmaster switches, they really look like something you'd normally see in the cockpit of a futuristic sci-fi spaceship.
    :thumb:
  19. greywolf
    15 Oct 2004
    Thanks for the resource, I'm going to order some now! I've heard of these guys(McMasters), but never checked them out...I'll be browsing for awhile :)
    Thanks again, these will be just the ticket for my mod!!
  20. Captain Slug
    25 Nov 2001
    Just so you know, McMaster will not list you the shipping price until the item is shipped and you receive the resulting notification e-mail. This is because they charge you exact shipping instead of an estimate. I've found their shipping to be extremely reliable and prompt.
    Not to mention that they have an insanely wide variety of products to choose from. My hardest decision there is usually what do I NOT need from here or where do I start.
    :hehe:
