Project: Modding Lian Li PC-60 (UPDATE: 16.4.2005 // Stealth Mod)
Discussion in 'Project Logs' started by drinn, 22 Mar 2005.
  1. drinn
    drinn What's a Dremel?
    16 Jul 2004
    Hi again dudes!
    It's been a long time of my last, broken mods called as Project Sindy (barbie car) and a mod which I didn't have strength enough to continue it, called as Project PlexiCase. But now, I have started a new project called as "Project: Modding Lian Li PC-60". This is also my birthday mod! :) (my birthday coming on 27.3)
    The components
    AMD Athlon 64 3500+ 2.2GHz Boxed S939 (ordered)
    Abit AN8 Fatal1ty (nForce4 Ultra, Socket 939)
    Zalman CNPS7700-ALCU (ordered)
    2x A-Data Vitesta 512MB PC4000 DDR500 (ordered)
    Connect 3D Radeon X850 XT 256 Mt PCI-E (ordered)
    Creative Labs AUDIGY 2 ZS PLATINUM PRO
    Lian Li PC-60 (ordered and started the modding)
    OCZ ModStream 450W
    Boogie Bug, UV React wire sleeve kit, Cable sock serie , UV yellow (ordered)
    Revoltec IDE (UDMA133) kaapeli 90 cm, UV orange (ordered)
    Revoltec IDE (UDMA133) kaapeli 60 cm, UV orange (ordered)
    Revoltec FDD45PF Floppy drive kaapeli, UV orange (ordered)
    The packets
    Products from the first order in together (the hard disk's comes to my server and my father's work computer)
    Revoltec UV orange IDE & Floppy drive cables
  2. drinn
    16 Jul 2004
    Lian Li PC-60
    Modding Lian Li PC-60! :rock:
    Some little test wiring made and observing the case:
    Setuping the sound attenuation
    The case from back and front
    More modding coming soon.. (on this week? :) ) when I get other components
    See ya soon! :hip: :rock:
  3. z\\\\ffs
    z\\\\ffs What's a Dremel?
    2 Aug 2004
    go on dude :)
  4. tsa cain
    tsa cain What's a Dremel?
    14 Mar 2005
    im gonna watch ur progress this could be a very nice looking case(could be its a LOT nicer than mine stock :duh: )
  5. drinn
    16 Jul 2004
    Ouh.. I forgot my modded Ulti-Mat. I will use same blue color on the front panel of Lian Li :)
  6. mattthegamer463
    26 Nov 2004
    oooh, X850. that set you back a bit, im sure. cant wait to see this thing running!
  7. roachm
    roachm What's a Dremel?
    16 Nov 2004
    Nice case, nice cpu, nice gpu, now all you need to do is hurry up cause this is gonna be hot :D. :)
  8. Anthony
    Anthony What's a Dremel?
    6 Jan 2005
    Nice mod. :thumb:
    Mistä sä ostit tota uv-pyöristettyä kaapelia?
  9. (X)TORNADO(X)
    (X)TORNADO(X) What's a Dremel?
    26 Feb 2005
    Nice mode... :thumb:
  10. Isuo
    Isuo What's a Dremel?
    13 Oct 2004
    Good start.
    Offtopic:
    Anthony, vekkoaupasta tai jimms pcsuperstoresta
  11. drinn
    16 Jul 2004
    http://www.only4pro.com
    RAM-memory and Cooler arrived !
    I'm sorry about these little bad pictures
    Here is the new entry which I got today:
  12. Pitbull
    Pitbull What's a Dremel?
    20 Mar 2005
    pretty start but go on!! :D
  13. Scaleo^
    Scaleo^ Guest
    Olalaaa, A-Data Vitesta rammit :D Taitaa palaa aika paljon rahaa tohon koneeseen?
  14. drinn
    16 Jul 2004
    Se jääköön salaisuudeksi :)
  15. drinn
    16 Jul 2004
    SuperPi & 3DMark tests with my old PC
    Components of my old PC:
    MSI K7T 266mhz Pro 2-U
    AMD Athlon XP 2400+ 2000mhz
    GeForce 4 Ti 4400 128mb TV-Out
    2x Kingston 512mb DDR 266mhz
    2x Maxtor 80gb 7200rpm
    Antec 350W Power
    SuperPi 1M (1min 8s): http://www.drinn.info/projektit/modding/imgs/superpi/vanha_kone_superpi_1min8s.jpg
    SuperPi 8M (12m 17s): http://www.drinn.info/projektit/modding/imgs/superpi/vanha_kone_superpi_12m17s.jpg
    3DMark 03: http://www.drinn.info/projektit/modding/imgs/3dmark/vanha_kone_3dmark03_1646pst.jpg
    It will stay on the future what results I'll get with my coming new PC :naughty:
  16. drinn
    16 Jul 2004
    COMPLETED!
    Check out this pic:
  17. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    :D You sod, was looking forward to seeing it finished :lol:
  18. Mada
    Mada Minimodder
    3 Feb 2005
    As was I, certainly looks like a promising project. Really do like those Lian Li cases even though I have always had coolermasters myself.
  19. Pitbull
    20 Mar 2005
    what funny I must almust laugh:S :duh: :duh:
  20. drinn
    16 Jul 2004
    UPDATE: 3.4.2005
    Hi dudes!
    I have installed the iron of my new PC and it works great :)
    I got little problems with Fatal1ty AN8 mainboard's IE1394 technology, but it's happily fixed now.
    Here are some new pictures (more are coming on next week)
    Little tangle, isn't it? :D
    Some bad light pics
    Wiring work is coming next ;)
    Temperatures
    SuperPI 1m = 40s :)
    http://www.drinn.info/projektit/modding/imgs/kone_kunnossa/uusi_kone_superpi_40s.JPG
    See ya soon! :cooldude:
