Project :: Moondust - Complete
Discussion in 'Project Logs' started by Leeum, 22 Sep 2005.
  1. frodo
    frodo What's a Dremel?
    1 Nov 2003
    **hugs leeum repeatedly**
    DOOOOODDDD!!! PAINTED FRONT BEZEL TODAY!!!! :D yay
    :D i love your project, shows how clean and spunky a cheiftec can really be :D you be my inspiration o' fellow cheiftec'r
    now... your next project best involve another chieftec!
    cant wait to see the painted front! will look su-weet
  2. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Watch this space :D
  3. Been
    Been What's a Dremel?
    11 Jul 2005
    it's been said but it must be said again, this whole project is just awesome, i expect you to win something in the competition :D
  4. Leeum
    16 Feb 2004
    The project is on the home stretch now; I figured I’d show a few progress pics of the internals before I reach the finishing stages. I received the final parts back from the painters tonight…I’ll hold you all in suspense ;)
    Consider this update dedicated to Da Dego who has been PMing and telling me to get my butt into gear :hip:
    In preparation for the front bezel coming back, I got the case riveted back together. I previously used self-tapping screws but the bezel wouldn’t fit as the heads were too big.
    Pop :D
    Now the internals, after getting the loop up and running I tried a couple of UV dyes before finding the perfect one.
    I first ran a mixture of BlueMotion and Blue revealing dyes but as you can see, it failed to match the cable sleeving.
    I decided to try something with a darker shade; I drained the loop and filled it with some fresh water. I then added some Dark Blue UV Dye from Coolercases, it only took a couple of drops and the water had change to an awesome colour.
    I let the system bleed motherboard side down, once the pump intake hose below the reservoir intake hose solved the problem of frothing water right away.
    Here are the pictures at the current stage, I nabbed the Graphics department tripod for the weekend so they should be better than usual :p You’ll have to newly painted bits and bobs and the untidy cabling.
    Full on shot from the top.
    From the side.
    From the left side.
    and when the lights dim down… :D
    As you can see, the new UV dye matches the internals much better :)
    Zoomed in slightly.
    Side shot.
    Zoomed in again.
    Here’s the lit up top section of the case. There’s another 2 UV cathodes mounted at the top to make the UV Perspex on the top panel glow :)
    The Aquatube is fitted with a white LED but as the water is blue, it provides a nicer colour than a plain blue LED :)
    That’s all for now, updates will be on a regular basis now as the project is drawing to a close :(
    Until then, mod on :dremel:
  5. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Wow, this looks so sweet, as I said online earlier, but it really does! :D
  6. blue_lawnchair
    blue_lawnchair What's a Dremel?
    25 Mar 2005
    Great job, very clean and love the color. :thumb:
  7. Grunnsetning
    Grunnsetning What's a Dremel?
    11 May 2005
    Very nice project. Glad to see some more with bigger bore tubing, that 1/4" has no character IMHO.
    Just a suggestion that I would consider, the hose going to the inlet on your pump seems to block alot of your hard work put into the water blocks. Maybe look at running it down low towards the back of the case then up to where you can see more of your highlights. Like I said, just a friendly suggestion.
    Mod on!
  8. Leeum
    16 Feb 2004
    Cheers for the kind comments :)
    Very good point, when getting all the tubing attached I tried all sorts to make it look tidier but there were no other places it could go.
    Thinking about it now, I should really have mounted the pump somewhere differet, I'm happy with it though.
    Cheers with the suggestion :thumb:
    Keep the comments coming peeps :D
  9. frodo
    1 Nov 2003
    sexy!
    cant wait to see it with the front on mate... w00t
  10. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
    w00t! Yaay updates!
    Looking terrific, Leeum. Very nice attention to detail with all the little white LEDs! I cant' wait to see what's happened to the front bezel, as it tends to be my least favorite part of these cases. But I'm sure you've got something terrific in mind for it!
  11. frodo
    1 Nov 2003
    love the way those molex's just glow under UV :D
    is the front done yet? i cant wait to see it all done :D
  12. Shadowed_fury
    21 Nov 2003
    I think it is, Leeum wouldn't show me earlier the meanie! :p
  13. frodo
    1 Nov 2003
    Same! hes so mean isnt he!
  14. Shadowed_fury
    21 Nov 2003
    Yeah! Tisn't fair! Though this is coming to an end, maybe Leeum wants to end it on a high? ;)
  15. frodo
    1 Nov 2003
    Or while he's high? lol j/k leeum dont murder me!
    i must admit, the suspense is killing me.... its so... unfair!
  16. Shadowed_fury
    21 Nov 2003
    And here we are, talking about Leeums case, when we should be finishing ours ;) hehe
  17. frodo
    1 Nov 2003
    I suppose.... but damn this is too sexay... i just want to see it so i get a splurge of inspiration (and somethign else) so i can get to work on mine again! ive hit like a point where if i dont see this my mod will never be completed... jokin'!
  18. Shadowed_fury
    21 Nov 2003
    Ok........... *runs*...
  19. Leeum
    16 Feb 2004
    LMAO, nice little discussion been going one while I've been away! :D Thanks for all the comments.
    All will be revealed very soon Da Dego! :)
    Just to let you know...I finished the case tonight and I'll be taking the finished photos tomorrow while I have the tripod :D It may be mid next week before they're posted though, I've still got alot of updates to show.
    Sit tight :thumb:
  20. Shadowed_fury
    21 Nov 2003
    No! Not fair! :/
