Project :: Moondust :: Update 16/09/05
Discussion in 'Project Logs' started by Leeum, 1 Feb 2005.
Thread Status:
Not open for further replies.
  1. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    I seem to be on a bit of a roll, may aswell keep on going ;)
    I de-riveted the bottom panel; this will need to be painted as it can be seen on the case.
    The cuts I made to the top and side panels were filed. I used needle files on the corners and then sanded all the cuts with 600 grit sandpaper.
    My next task was to get the panels sanded down in preparation for painting. I used 80 then 220 grit on the electric sander.
    A picture my dad took of me sanding :p
    Managed to catch the sun going down on these shots. The panels (mostly) down to the bare metal, I couldn’t apply pressure with the sander on some of the cut areas so they had to be done by hand. What matters is that the bumps of the textured paint are now smooth :)
    From another angle.
    A shot to show how smooth the cuts are after extensive sanding :D
    The panels are off to a local painters to be painted silver properly, should have them back this week and I can begin setting up the water cooling.
  2. Acid Burn
    Acid Burn ..look but don't touch..
    14 Mar 2004
    Man! those cuts are so nice! i just love the design! this is going to be up there with the best mods mate :naughty: Keep it up lad! :dremel:
  3. Jordanis3r
    Jordanis3r Jigsaw Master
    8 Jan 2002
    its looking sweet as dude - keep up his workrate and itll be finished before the summer is out!
    nice one:D sanding turned out ok didnt it :)
  4. Leeum
    16 Feb 2004
    Woo, cheers JS :D Major kudos to ya for sketching and sending those designs, they've turned out great, i'm very happy with them.
    Look forward to seeing your work on your new setup :thumb:
  5. pc-modd.dk
    pc-modd.dk What's a Dremel?
    22 Apr 2005
    Very nice cutting
  6. frodo
    frodo What's a Dremel?
    1 Nov 2003
    doood, awesome work, i also envy your hair :mad:
    damn man, this is going to look SWEET!, your a good worker, your dad should be proud of you :D lol
  7. _ferry_
    _ferry_ What's a Dremel?
    22 Apr 2004
    I still love the window design, nice design :dremel:
  8. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    Hey Leeum, your dad keeps a good lawn...........does he use weed n feed :D
    Sorry dude
    One thing with sending your paintwork out is that it comes back looking so good and when you've put that much effort into sanding something its worth it with out a shadow of a doubt IMO
    This weathers been great for working out doors...............imagine doing that in January :duh:
    Top quality..............keep going bud :thumb:
  9. hobbs
    hobbs What's a Dremel?
    24 Jun 2005
    how much will the painting cost? or are you jsut getting it chromed?
  10. Leeum
    16 Feb 2004
    Cheers Paul :thumb: I totally agree about the paintwork thing, I didn't fancy taking any chances with a spray can. The front bezel will have to go to the painters at a later date, I've still got some plans for that yet.
    The painter didn't say how much but he's assured me it "won't be much" :naughty:
    Thanks for all the kind comments :D
  11. Been
    Been What's a Dremel?
    11 Jul 2005
    it's looking really good. that word is coming to my mind again
    awesome
  12. firestarter03
    firestarter03 What's a Dremel?
    16 Sep 2004
    Can't wait to see how the panels turn out Leeum, keep up the good work :thumb:
  13. frodo
    1 Nov 2003
    i know a professional painter, its awesome, but i havent spoken to him for a good few years,will have to see what he can do for me
    but damn man, this is gonna be awesome! cant wait to see how it comes back :D
    what are your plans on the front??? im guessing some bondododododo?
    speak to ya' on msn soon
  14. Leeum
    16 Feb 2004
  15. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    That ain't the sky. No, it's impossible. :D
    That's awesome work dude. Very impressive!
  16. Been
    11 Jul 2005
    that's a great job. looks great.
  17. frodo
    1 Nov 2003
    :O seriously
    man, wtf, that is to 1337 to be 1337, its like :O
    man
    sick!
  18. Leeum
    16 Feb 2004
    Cheers frodo :D Will be updating soon, just need to get some decent pictures ;)
  19. frodo
    1 Nov 2003
    hey mate, want to get me in touch with your professional sprayers lol :D
    i really want my bikes tank sprayed properly!
  20. ezland00
    ezland00 What's a Dremel?
    22 Jul 2005
    Hello, i'm trying to mod my case too, can you tell me how did you remove those screw apart? Its does look like a screw
Thread Status:
