Project: Nexus - 3-15-07
Discussion in 'Project Logs' started by Mod_God, 23 Dec 2006.
Case frame Bare, Black or Red?
  1. Bare Metal
    17 vote(s)
    19.5%
  2. Red
    25 vote(s)
    28.7%
  3. Black
    45 vote(s)
    51.7%
  1. Mod_God
    Mod_God What's a Dremel?
    7 Dec 2006
    This is project Nexus, the basic theme behind the mod is just a clean looking case with some innovative ideas and nice looks
    Concept art:
    So This is the case I am using for the mod
    Sorry for the bad image quality
    I started by cutting the front 120mm fan opening supports out
    Marked up:
    Cut out:
    Then I proceeded to take the top of the case off to cut the hole for the fill port and radiator:
    I then masked the top, and lined the radiator up to mark it:
    After all that measuring and marking I finally got to cut the holes:
    Didn't turn out to bad
    Looking at the fill port cap it look like it needed polishing:
    So I did:
  2. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    blah... was too quick.. sorry
  3. Mod_God
    7 Dec 2006
    It's ok I was having trouble posting pics but i got it :D
  4. Mod_God
    7 Dec 2006
    After a small break I began work on re-assembling the top of the case:
    Turned out pretty good:
    Aside from that nasty mark the dremel made everything went pretty smooth
    You can probably see where I am going with the fillport:
    Any comments or questions, feel free to post
  5. Mod_God
    7 Dec 2006
    Heres a concept of the front it may or may not look like this, I haven't decided on it yet
  6. Mod_God
    7 Dec 2006
    Parts!!!
    Heres some parts ill be using in the mod.
    Window molding:
    Red fans:
    Dual 120mm radiator:
    Bulgin vandal resistant switch & HDD indicator LED:
    Reservoir and two UV cold cathode tubes:
    And last but not least, the Maze 5 water block:
  7. Supra55
    Supra55 What's a Dremel?
    10 Oct 2006
    Looks good.
  8. NysoO
    NysoO Handcrafted
    2 Nov 2006
    Looks sweet!
    Why does Lian-li put those fangrills there? It's not like they are protecting you from putting your fingers in the fan.
  9. Mod_God
    7 Dec 2006
    heres some concept art of the radiator cover for the top of the case tell me what you think
  10. Mod_God
    7 Dec 2006
    Switch Plate!!!
    I spent a few hours today on the switch plate.
    Marked up:
    Cut:
    Polished:
  11. Mod_God
    7 Dec 2006
    Switch Plate!!!
    Overall it turned out good, I think I still need to polish it some more.
  12. Mod_God
    7 Dec 2006
    More work
    I did some more work, this time on the radiator hole cover
    Marked up:
    Cut & filed, soon to be polished:
  13. Mod_God
    7 Dec 2006
    Leave some comments, give me some ideas, I need some inspiration :D
  14. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    Comment, it looks pretty good so far!
    Idea: paint the fill port red too
  15. Mod_God
    7 Dec 2006
    Fill Port
    I got the fill port blue to fit the whole blue theme im shooting for, im gonna have a blue water cooling system and blue back lit plexiglass in some areas, but thanks for the input
  16. Mod_God
    7 Dec 2006
    So yeah, I don't currently have access to a camera right now but ill update as soon as I can. things are coming along quite well, so tell me what you think :D
  17. Mod_God
    7 Dec 2006
    Mobo Cover
    Heres some concept of the soon-to-be motherboard cover:
    Im thinking im going to add some 40mm fans and a back lit "Nexus" logo
  18. Mod_God
    7 Dec 2006
    Top Is Done!
    I finished the top of the case yesterday:
    Theres also a dual 120mm radiator under those fans
    Hooked up:
    So tell me what you think.
  19. kylelnsn
    kylelnsn What's a Dremel?
    19 Dec 2006
    2 Words, PURE PAWNAGE thats the way you can describe this, i love it pure sexy ness, very nice good job you done keep up the good work, and keep going it rocks nice job!
  20. Mod_God
    7 Dec 2006
    Switch Plate!
    So I did some work yesterday and got the switch plate done for the most part:
    Backlit!! (hooked to my old case)
