Project : / noname yet / update ! 09.03.2005
Discussion in 'Project Logs' started by hmekk, 6 Mar 2005.
  1. DarkInferno
    DarkInferno Minimodder
    28 Nov 2004
    Finally loaded:
    Not looking too bad at all, I agree with Protius-X about putting the cc behind that crossbar to stop glare, another idea is to cut out the punched out 12cm fan grills at the back and fit it with wire grills, for a couple of reasons...It will look a lot cleaner, much better airflow, and less noise, unless of course you have other ideas for that part of the case ;)
  2. Pygo
    Pygo Rick Relixed
    26 Jan 2003
    Nice window hmekk.
    Are you gonna watercool it?
    also, what will you be using this computer for? just a case instead of the poobox you did?
  3. Geektechnica
    Geektechnica Minimodder
    11 May 2004
    Does anyone know where I can get this case in the US?
  4. matrixops
    matrixops What's a Dremel?
    17 Feb 2005
    I like the window, excellent design. I will be watching this mod.
    MatrixOps
  5. hmekk
    hmekk What's a Dremel?
    17 Jul 2004
    thanks for all good comments
    i cant continue before i get some sanding disks to work with tose edges
    but sleeving and psu modding pics will come soon ( soon as i have time tu turn off the computer )
    :clap:
  6. hmekk
    17 Jul 2004
    little update
    just almost finished sleevind ....
    but i ran out of heatshrink :waah:
    pics :
  7. cc rass
    cc rass What's a Dremel?
    28 Dec 2004
    Kui küsida tohib siis äkki seletad kuidas seda täpselt sleevisid. (ma liiga väsinud et inglis keeles kirjutada ja loodan et ei ole inglis keel siin foorumis kohustuslik)
  8. hmekk
    17 Jul 2004
    pmst on küll kohustuslik
    googlist leiad vastuse ... otsingusse how to sleeve cables
