Hi All, Now I've been using it on my Laptop and used it on my main rig and it runs well on my current hardware it can take a little tinkering sometimes with drivers and some hardware but on the whole it works fine for me depending on your setup. Have any of you guys actually tried/installed on you systems? From what I have seen the best kit to have is Asus & Gigabyte motherboards seems that alot of the hardware they produce has a driver for. One of the main issues I had was changing to ACHI in the BIOS when that is on windows will not boot not an issue as I don't often use so I have to readjust the BIOS.
I did it a looong time ago (around 2005) long before iDeneb was about and it took a bit more to get it running. Lots of fun, especially on my Athlon 64 system. But I've moved on, this weekends project is a Server 2008 R2 install for my fev-serv
