Project PC-70
Discussion in 'Project Logs' started by mctoby, 19 Aug 2002.
  1. mctoby
    mctoby What's a Dremel?
    28 May 2002
    Not much to say atm this is what the machine looks like at the moment:
    what is planned for the future?
    VFD Bit -Tech one me thinks as it fits in a single drive bay....
    Tidying up the inside of the case, a bit messy in there right now
    Replace the standard Lian-Li window panel with something nicer...
    :idea:
  2. macroman
    macroman The One
    3 Sep 2001
    Any pic or details on how you did the mods? :baby:
  3. linear
    linear Minimodder
    5 Oct 2001
    Yeah, let's see the backlit live drive... :baby:
  4. mctoby
    28 May 2002
    some details on the Live! drive and DVD mod here the Rheo is a rip off from your design macroman :lol: the pots used are from maplin 10k with on off switch FW42V and a QB68Y so the backlight for the individual knobs as well as the red indicator switches on off with the fan. the electronics part is from a tip on overclockers, very simple but is working okay....
  5. m00min
    m00min What's a Dremel?
    6 Jul 2002
    this isn't a diss, but why does everyone by lian-li cases and mod them they all look indentical?
    they look nice but they are all the same with just different bay conversions at the front
    m00min
  6. Hiren
    Hiren mind control Moderator
    15 May 2002
    Looks very very cool although maybe some color on the front would be nice. Keep it up :lol:
  7. mctoby
    28 May 2002
    I can only speak for myself but the reason I chose the Lian-Li is that I like the design of the PC-70 nice and clean lines.
    Some mods in progress at the moment that are not on the front of the case, hopefully I will have them done and some pics posted by tonite....
    :dude:
  8. Digital Sin
    Digital Sin What's a Dremel?
    29 Jul 2002
    excellent stuff you got going there, i have a lian li myself (pc61) and i think they look very good, the stock design isnt the best but when you mod the hell out of them they look damn cool. :dude:
  9. funy
    funy What's a Dremel?
    23 Oct 2001
    i think a lot of people bought them when they first turned up, and only just got round to modding them maybe?.
    I have a pc65 with the window, and the reason you see many similar mods is becuase they look best with either stealthed or painted or remoddeled faceplates on the cd drives so they match up with the rest of case
  10. mctoby
    28 May 2002
    UPDATE!
    Okay here is my latest update to the project it started something like this:
    mark it for size:
    start etching:
    yeah I know everyone and their mother is using th biohazard, well I like it just like all the rest ( and their mothers) :lol:
    after the etching was done it was mounted in its place, what the image is supposed to show is that the window is flush with the panel its mounted in bit too crappy camera to show it tho:
    added some led's.....
    and here's some more pics:
    hope you like it...... any questions on how something was done just ask.....
    oh and btw dont ever mod your PSU unless you know what you are doing..... theres like things in there that can seriously kill you
    :dude:
    oh and yes I know that the blue ring is not as bright as the red parts thats because I ran out of 4mm plexi and had to use some thin stuff I had kicking about I'll replace it as soon as I have a chance
    :D
  11. funy
    23 Oct 2001
    nice looking mod m8 :D
  12. mctoby
    28 May 2002
    changed the plexi for the blue ring to a thicker one...
    :dude:
  13. hprcrazyguy
    hprcrazyguy Minimodder
    31 Dec 2001
    I really like that window etch on the power supply. :dude: :D
  14. bust0aster
    bust0aster What's a Dremel?
    11 Jul 2002
    nice work. 2 questions though
    how big is the etch? theres nothing really to compare it to for size.
    what did you etch it with? if you used a dremel what bit did you use?
  15. mctoby
    28 May 2002
    The etch is about 85mm across its fitted in the hole for the 92mm fan the plexi was etched with a dremel (well a cheap ass homebase rip off) the bit is like a tiny straight cutting router bit as far as I remember it came with the tool.
    :cooldude:
  16. Shadowspawn
    Shadowspawn Another hated American.
    1 Jul 2002
    I can't make out the pictures...why does the etch appear black when not lit up? It also appears to be thicker than the surrounding plexi?
  17. mctoby
    28 May 2002
    the black in the non lit pics is the template I used to see what to etch as I know I wouldnt be able to etch it freehand... just a printout of the symbol....
    the etched parts are thinner than the rest of the plexi sheet
    :dude:
  18. Digital Sin
    29 Jul 2002
    thats some nice etching, i did a little one on my case as well. etching is not too hard, but it is VERY time consuming.... even moreso than regular dremeling. however, with patience (and a few spare hours) it is very rewarding. nice job.
  19. mctoby
    28 May 2002
    Hey got this in the mail yesterday:
    watch this space....
    :dude:
