Project plexicube IS DEAD
Discussion in 'Project Logs' started by metalgod, 25 Mar 2003.
  1. metalgod
    metalgod What's a Dremel?
    15 Feb 2003
    This case isn´t still finished, it needs some hinges to make da roof =P it also needs some lights.. maybe green cc? havent decided yet :/
    Soon i´ll get some better images, but so far only one ****ty webcam pic :/
  2. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    Looking good, but wouldn't it be better to have the mobo contacts closer to the wall, so you don't have to run all the wires through half your computer?
  3. ToM
    ToM mmmm, blud
    14 Aug 2001
  4. metalgod
    15 Feb 2003
    it´s quite big and my mobo is kinda small too :/
    dimentions are 400*400*400 mm, so it´s a perfect cube :)
    actually i was planning to put watercooling and neon too, but i´m out of cash right now :/
  5. ToM
    ToM mmmm, blud
    14 Aug 2001
    if your not going for watercooling, id chop down to the top of the moby and have half a cube! also, is that an at motherboard? i see it has the old din type socket for the keyboard :D
  6. metalgod
    15 Feb 2003
    i will build watercooling later because temp is kinda high in this case :/
    yes, an old AT =P
  7. ToM
    ToM mmmm, blud
    14 Aug 2001
    so if its an at, what spec is it???
    id buy a new setup first then the wc stuff :D
  8. metalgod
    15 Feb 2003
    planning to buy up to 2ghz(cel 533 is now) and wc, we´ll see what happens.. cash i mean =P
