Project PreChromed [updated august 31]
Discussion in 'Project Logs' started by notatoad, 10 Jul 2005.
  1. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    hey everybody
    i've been lurking at this site for about a year now, and have finally started my first project. this is my first pc mod ever, although i have been tinkering with stuff for a long time.
    the basis of this project will be my love of shiny things. i will be painting my case shiny black, and using chrome accents. the problem is that i have no place to get stuff chromed, so i will be using lots of stuff that is already chromed, and modding it to work on my case (thus the name, preChromed). On to some pictures of the case i will be using:
    [​IMG] [​IMG] [​IMG]
    it is an old pentium case. i have three of them in my basement, so if i screw up, no worries. there's lots of room for experimentation here.
    first thing that has to be done is dremel out the back panel so that my motherboard i/o shield will fit in.
    can't find a finished pic of that one right now
    then, cutting a blowhole in the front to let some airflow in
    [​IMG] [​IMG]
    guess what this is for
    perfect size
    mmm... chrome ducting
    i'll probably move that fan forward to be flush with the front of the case later
    and then, my parents took their digicam on holidays with them.
    since then, i have bondoed the front of the case smooth, and put a window(with chrome border) on the side. still to come, i will be fixing up the wires inside the case, painting, and putting in lots of leds. also, my cd drives will be stealthed, i will chop up a fan controller, put usb ports on the front, and maybe a window behind the motherboard. more pics when my parents get back next weekend, or sooner if i go buy a cheap camera
  2. J-Pepper
    J-Pepper Minimodder
    20 Jul 2004
    I like what i'm seeing so far... good luck and i'll be watching!
  3. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    looks like some good ideas
  4. pc-modd.dk
    pc-modd.dk What's a Dremel?
    22 Apr 2005
    nice work mate:)
  5. rewris
    rewris What's a Dremel?
    21 Oct 2003
    looking FULL of potential
  6. kaotic504
    kaotic504 What's a Dremel?
    20 Jul 2004
    creative way to use a sink strainer. grreat job man, can't wait to see more work!
  7. simosaurus
    simosaurus What's a Dremel?
    12 Jun 2005
    ingenious use of the sink plug! i can see a lot of people using that idea now :)
  8. notatoad
    25 Jun 2004
    thanks for all the great replies everybody. i think i'll go buy a cheap camera today, and start painting
  9. Phaeton
    Phaeton What's a Dremel?
    8 Mar 2005
    Bondo works great on plastic cases like the one you're working with; it gives you a lot of choice in what your fascia ends up looking like.
    Good luck!
  10. notatoad
    25 Jun 2004
    that's the plan. i've got the front completely smooth right now, one big hole for the front intake, and then i will cut slots for my cd drives. still no camera.
    also, the entire case, minus the front panel have been primed and sanded to 600 grit, ready for their shiny black paint.
    update with pictures coming sunday night, and i'm still trying to find a local source for red leds, and waiting for my plexi to arrive
  11. notatoad
    25 Jun 2004
    update aug 31
    i did some more work on my case today, got the black paint on, and fixed up the bondo on the front bezel. here is what the case looks like right now
    i had high hopes for this window, but it is really not turning out so great. i cant get the little metal tabs that the rivets go into to sit flat against the plexi, so they look really ghetto. also, i misdrilled some of the holes so i am proably gonna have to cut a new plexi part. the chrome border is the ring that goes under the element in a stove, with the center part cut away
