Project Q-black
Discussion in 'Project Logs' started by Snitch, 15 Sep 2003.
  1. Snitch
    Snitch Supremodder
    24 Apr 2003
    HELLO DUDES!
    Im starting to mod my q-tec bigtower now!!!
    This is whats it looked like before(here u go bard):
    So this is what i have done yet.
    Bought 2 cans of black shiny and sprayed the right side with it.
    Dude it looks awesome, pics comming soon (i hope)
    This is the plans:
    I found a place to buy UV LEDs and pens and they also have very cheap cold cathodes so i think ill buy it there.
    A blowhole in the top, 120mm i think and i yhink it will be a titan aluminium fan. The 120 LED fans are so freaking expencive :miffed:
    I made a fast sketch of a window design:
    Give me ideas please, and a tip for a name!
  2. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    Snitch, we even have the same parquet floor! Except the squares in my house are much smaller, so since I'm used to see the small squares, the case looks tiny :).
    Looking at your case, then at mine, makes me realize that I have come a long way...
    Please submit pics of what you have done so far, and I am looking forward to the next update!
  3. pranks7er
    pranks7er mange tout
    25 Dec 2002
    project: dont worry bard i wont copy all your ideas :D
  4. Snitch
    Snitch Supremodder
    24 Apr 2003
    Prankster LOL!
    And the cdfronts are going to be RED!!!
  5. Thunder_return
    Thunder_return What's a Dremel?
    8 Jun 2003
    Interesting project Snitch!
    A name suggestion: Black Laser
    You have chosed the colour that rulez: BLACK!
    Keep your projects updated! And please look at my bigtower
    project. Come with ideas or just tell me how it looks.
  6. Snitch
    Snitch Supremodder
    24 Apr 2003
    Q-black... how does that sound?
  7. Snitch
    Snitch Supremodder
    24 Apr 2003
    Just realised it will be freakin hard to come up with new ideas...
    Bard already done everything...
    Found cheap UV-diodes, ran happy home and saw bard already did it :miffed: :waah:
    EDIT: (just to dont post to many in a row...)
    I'm going to start cutting the blowhole inte the top as soon as i buy a 120 fan (have to take pictures, im going to write a guide)...
  8. Thunder_return
    8 Jun 2003
    Sounds good!
    Where did you find the cheap UV-leds?
  9. Snitch
    Snitch Supremodder
    24 Apr 2003
  10. bard
    8 Mar 2003
    Snitch, the UV LEDs from jxddata (Sunbeam) are actually just 1000mcd, even though it says 8000 mcd. (I learned that from the microplex.no site, where they also sell these LEDs).
    No I haven't. I'm not finished yet! :D
    When can we expect updates/pics on this project? Now? :lol:
  11. Thunder_return
    8 Jun 2003
    Yes,Gothic Snitch, it is cheap and you usually get what you
    pay for... Test them and post how they look , please.
  12. Snitch
    Snitch Supremodder
    24 Apr 2003
  13. bard
    8 Mar 2003
    That's so nice! Makes me want to paint mine too. Is it scratch resistant? Have you sanded between the coats? Are you using clear coat on top? Do you think I'm asking to much?
  14. Snitch
    Snitch Supremodder
    24 Apr 2003
    scrach resistant? dont think so.
    I sanded before i painted.
    No clear coat (yet?), does it make a big differense?
    No its cool dude
  15. SpeedFreak
    SpeedFreak What's a Dremel?
    28 Mar 2003
    is that the cable for a set of Philips HP890's i see there? ;)
  16. bard
    8 Mar 2003
    What's the next mod, snitch? (I hope it's filling and sanding the old power/reset buttons and making new ones :))
  17. Snitch
    Snitch Supremodder
    24 Apr 2003
    Whats a hp890?
    The next mod will be the window and then spraying i think.
    Bard: How do u fill?
    Ill ask my dad he surly knows
  18. Snitch
    Snitch Supremodder
    24 Apr 2003
    Hehu just cut the window and sprayed it, just cand find any moulding.
    I have a black cable but it is like 5 cm short :sigh:
    Pics of it comming tomorrow!
  19. bard
    8 Mar 2003
    Snitch, I used hole putty for filling. In Swedish it is called "spackel".
  20. Snitch
    Snitch Supremodder
    24 Apr 2003
    So lets contionue:
    Masked and marked up:
    Drilled a hole to start cutting from:
    Cut out:
    Heavy tools, cost my dad alot!
    And Painted:
    Dude that pic looks scab, well it isnt, its like the other painted side i posted before...
    I just need to find moulding!
    What do you think?
