Case Mod - In Progress Project: Rage in the Machine - Video Card mod 5/17
Discussion in 'Project Logs' started by TheGreatSatan, 24 Apr 2011.
  1. TheGreatSatan
    TheGreatSatan Member for 17 years!
    5 Aug 2005
    Specs:
    AMD 1090T X6
    MSI 880G-E45
    4GB DDR3-1333
    Radeon 6850
    80GB Intel SSD
    700 Watt PSU
    I saw this skull on eBay and knew I had to have it on a wicked new build
    I chose a black Raidmax case as the canvas. I knew it needed to be plain because I would be ratically changing it and didn't want any snazzy features poking through
    It came with a cheap PSU, but I'm not using it
    Every evil case starts with red
    A 120mm intake fan is essential when using heat trapping expanding foam
    And another 120mm fan on top. Yes, it is off center on purpose
    Remember this boney hand? I pulled it off my GreatSatan mod
    Here's a small intake fan for the right side
    I took this intake fan from my Clowned mod that my Mom never used
    I'm adding mounts for the spine I took from TheGreatSatan as well
    Here's where I break out the metal wire
    I guess this is supposedly used to clean paint brushes, or store them, or something. To me, I see a cool grill
  2. DeafGamer2015
    DeafGamer2015 Minimodder
    5 Jun 2010
    whoa nice start there man.. that'll be an awesome computer when you're done!
  3. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    Lol! At first I was thinking ^^ bumped up an age-old thread. So what are you going to change from GreatSatan?
  4. password
    password What's a Dremel?
    28 Dec 2010
    nice start looks like it is gonna be good :D
  5. Radcarton Mods
    Radcarton Mods I do graphics
    5 Aug 2010
    Looking promising..excited to see where this goes :)
  6. KidMod-Southpaw
    28 Sep 2010
    Great start, the red looks great!
  7. TheGreatSatan
    5 Aug 2005
    The skull and something else coming...
    The arm also came from my GreatSatan mod. I originally thought this would be a terminator mod, since it's literally terminating some of my past projects
    Time to finally move on to the expanding foam. I have a bit of experience with this stuff and will make it look better than ever
    I had to carefully add foam to the DVD door without making it stick shut
    Then I added more to the top around the top exhaust that I purposely cut off center
    Then I got to painting
    Next comes the skull
  8. Guest-23315
    Guest-23315 Guest
    Grr... You stole the title I was going to use for my project :p
  9. TheGreatSatan
    5 Aug 2005
  10. KidMod-Southpaw
    28 Sep 2010
    Awesome foam! That is very original! I did like it better when it was white though :(
  11. TheGreatSatan
    5 Aug 2005
    More like brain matter!
  12. TheGreatSatan
    5 Aug 2005
    I used a wire mesh frame that I slid the skull over and forgot to take a picture of it. Then I filled it with tons of foam.
    Here's where this mod will differ from many others. I will spend a lot of time with a small brush making it absolutely perfect
    I made sure the drive worked. Guess what? It didn't. I had to tear the old one away from the foam and put this one in. Then I had to refoam and paint...
    Annoying
    The USB ports are actually part of a hub that is plugged into the real front panel ports. I put it on an angle because it looked better that way
  13. Cheapskate
    13 May 2007
    That eye socket looks kinda infected.
    It needs something in the mouth, but I don't know what.
  14. Javerh
    5 Sep 2006
    An apple?
  15. Fiyero
    Fiyero Vindaloovian
    20 Sep 2009
    This?
    CardJoe likes this.
  16. Warsmith
    Warsmith Enginseer
    5 Dec 2010
    Maybe one of those octopi USB hubs made to look like a tongue?
  17. TheGreatSatan
    5 Aug 2005
    Here's my motherboard
    And my spare 1090T
    I even had a spare Radeon 6850 reference card laying around
    All the parts are in and the system does start up. The motherboard is kind of cool because it has the power button right on the PCB
    I'm using an 80GB Dane Elec SSD. It says it's actually a (1st generation) Intel X25 that was made by Dane Elec. They read at about 150MBps, which is slow for an SSD, but still quicker than a mechanical drive
  18. Droih
    Droih Your too close if you can read this
    17 May 2010
    It's an cool mod, makes me feel ill if I use my imagination too hard :D How about some of that foam on the inside??
  19. TheGreatSatan
    5 Aug 2005
    Then it'll get hotter
  20. Droih
    17 May 2010
    that's true but since it will also isolate some, it should give better air flow for some well placed fans?
