project Sephiroth (o0o0o)
Discussion in 'Project Logs' started by ToM, 24 Mar 2003.
  1. ToM
    ToM mmmm, blud
    14 Aug 2001
    ok, ive decided to get my modding ass in gear and build a plexi case.
    i have to wait till easter hols b4 i do this, but these r the designs for my ickle lan box, what dyu all think?
    thats top layout view
    and thats from the front and right side.
    the psu and cd-rw/dvd will both be mounted on the same side, as this makes the front totally clean except for the on button, and the moby ports will be on the oposite side.
    i was thinking of a slot loading cd-rw/dvd as it will be easier to cut a slot into the plexi then try and incorperate the whole tray, it also gives me a lil extra room at the side of the case, without having to find somewhere to put it without too much clearance from the side.
    itll be a matx board with sound n lan already on it, as its just going to be a gaming system, thats pretty much all i need, so i dont need to use the pci slots. i would mount the cd-rw/dvd on its side, but it would block more of the view of the gfx card, which hopefull will have a spotlight going straight on it from a few hidden leds ;)
    do you guys n gals think itll work?
    what suggestions you got?
    edit:: the dimentions are going to be (inside) 320mmx320mmx125mm :D
    (outside)
    332mmx332mmx131mm :D
    so small
  2. Fowler
    Fowler mmm Cosworth
    20 Nov 2002
    Re: project bloo-lan
    nice to see you took my advice, but im very impressed with the design work tommeh!
    As for "will it work", I have no idea, but make sure u get some pics up mate! Of this in developement!
  3. Tanaban
    Tanaban What's a Dremel?
    6 Aug 2002
    Well, as far as if it will work or not... where are the fans?:eyebrow:
    Or is there supose to be enough air through the PSU?
  4. Iamgoodyy
    Iamgoodyy What's a Dremel?
    11 Nov 2001
    What about putting the bulky hardware items under the motherboard? That way you would have a direct view of everything on the motherboard, including that graphics card you have highlighted so well on. Looks good and a nice plan.
  5. Yo-DUH_87
    Yo-DUH_87 Who you calling tiny?
    6 Mar 2002
    Looks like you have a plan, go for it!
    Make sure there are lots of blue lights :rock:
    I might add, though, that imho you will need more than the PSU fan ;)
  6. Moreland
    Moreland banned
    16 Jan 2003
    Good Design Tommeh :) Good Luck in making it come real.
  7. ToM
    ToM mmmm, blud
    14 Aug 2001
    as for fans, there will be the psu fans of course, one intake above the hsf, one intkake above the gfx and an exhaust on the back.
    i want the case to be as "flat" as possible, which is why it is only as tall as the gfx.
    once i draw up plans for the panels, ill put em up and show you the full design, thats just the layout view ;)
  8. SilverBullet
    SilverBullet Banned
    14 Oct 2002
    Good Idea and Design tom.
    YOU going to use tinted plexi like we spoke about?
  9. ToM
    ToM mmmm, blud
    14 Aug 2001
    that plexi you showed me was only 3mm thick, which i think is a little too flimsy, although there wont be that much weight in the case at all.
    im not sure whether to go for blue or smoked atm, or even purple, that would be cool :D
  10. samuelellis
    samuelellis What's a Dremel?
    19 Apr 2002
    its looking good so far
    how about this for a name
    project cheryl's gonna nick this off me (as we allknow she will :lol: )
  11. ToM
    ToM mmmm, blud
    14 Aug 2001
    no, she is just gonna nick my laptop off me once ive finished here at uni. loads of fun!
    but ill have 2 pcs at home to play with, so i dont mind :D
  12. relix
    relix Minimodder
    14 Nov 2001
    project Sephiroth? I'm naming mine project Rinoa :D
  13. ToM
    ToM mmmm, blud
    14 Aug 2001
    think i might use smoked plexi and call it sephrioth actually :D
    that would rock!
  14. pranks7er
    pranks7er mange tout
    25 Dec 2002
    remember airflow is important
  15. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
    :rock: hooray for FF7!!! :clap: :naughty:
  16. qwertyuiop
    qwertyuiop What's a Dremel?
    27 Aug 2001
    Thats a cool layout. Its not that tricky to do , i did something similar a few years back and that took 3 months of lazy planning and about 5 days to make.
  17. relix
    relix Minimodder
    14 Nov 2001
    are those dual pentiums? passive cooled?? :eeek:
  18. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    I want one of those tiny cases toooooooo:waah:
  19. ToM
    ToM mmmm, blud
    14 Aug 2001
    nice lil case
    how hard was it to get the psu to work like that???
    its the psu in that design which is giving me the headaches...
  20. Jack
    Jack Minimodder
    22 Dec 2002
    Its strange but ive had the exact same idea!!!!!
    Got an epox 8RGA+ & a Gainward GF4 Ultra lying here waiting to get a new case!!!
    Basicly i thought id make a little case that was the width of a graphics card and just longer than a motherboard so its easy to transport to play games/svcd on a normal telly!!!
    As for the questions regarding cooling remember that the width of a graphics card allows for a full heatsink+80mm fan! also if needed 2x80mm fans next to the CPU!!
    1 thing that i wouldnt recomend is the placement of the PSU the way you have it wires are going to be coming out of 2 side if you know what i mean, What i plan to do is make a normal PSU flatter by bending the heatsink and hopefully it will fit resting on the PCI slots
    Get modding mate im close behind :) just finishing this damn lian li
