Case Mod - In Progress Project: Server OF NOD, the end! on page 4
Discussion in 'Project Logs' started by arkadur, 1 Nov 2008.
  1. Huca
    Huca What's a Dremel?
    15 Oct 2006
    The case is looking very good, the sleeving was ok but you can clearly see the orange to the right was a little to long.
  2. arkadur
    arkadur What's a Dremel?
    3 May 2005
    *huca: dont worry about that - i need to put the caps on those connectors..
    i decided to use my sow to cut the acryl panel
    finish to cut..
    i placed one of them
    and with this tool:
    i made a PSU cover, for all the case length
    from now - i call it "power area"
    i'll cut some drills for the PSU fan later
    perfect bend
    starting of connection panel
    a partition between MB area to HDD area.
    CPU, GPU pump - here
    that is for today in connection with working on the case
    and now - some work on the MB
    the DFI MB is so annoying, it's taking too much time to remove all the heat pipes systems
    stock cooler
    without cooler, and after some cleaning to the cpu, NB\SB and the mosfet
    i remove the OCZ ram sink
    but, in the third one - some cheeps decided they prefer to stay on the ram sink
    anyway, i got Domminator 2X2GB 1066 kit
    the ram
    ram cooler
    pre-assembly :
    mosfet block:
    with the ram water blocks
    but, i got a problem, i cant remove the sink from the new ram, because of the new ram higher then any other ram, and the water block , cant complete a full cover,
    so the solution is put them together..
    the CF
    last for today
    another updates will come soon..
  3. blackflag
    blackflag I Kill Dremels
    16 Oct 2003
    Are you planning on re-tapping those AC Ramplexes to G1/4?
    Also, if you want my 2 cents, I'd go with the Dominator fan over those ram blocks any day. The blocks aren't going to do much (if any) better than that fan.
    Sucks about that OCZ.
  4. jegerjon
    jegerjon What's a Dremel?
    10 Jan 2007
    I'm sorry arkadur, but I just find that very funny. Haha failed ram-sink-remove :hehe:
    Lucky for you, you had those dominator ram laying around. :)
    It looks good, keep going!
  5. arkadur
    3 May 2005
    a new update
    i decided that the Mozart is too small,
    so i'll keep it for another project.
    i bought two CM 590 chassis
    out of the box
    top
    both of the floor
    another one
    from the side
    removing all the rubbers, screws, plastic and more
    front
    other side
    back
    masking tape, to protect the corners of the case
    trying to place some parts
    with the MB
    as you can see - i cant install there triple rad..
    so, the GPU's rad will be on the case floor
    front
    another update:
    more parts! :D
    need the system without water? no problem...
    the doors, ready to cut
    the case are ready to work
    left
    paint sample.. i'll go with this in all the elements in the case
    you can see in green some of the welding area
    right
    welding areas..
    back
    better then the mozart
    MB back plate ..
    all i need is to paint the cases, weld them together
    cut the doors and the roof, and that it.
    on the roof i'll place a 3X120 radgrilzz with red LED fans
    that's it for today.
  6. arkadur
    3 May 2005
    here it's come.. update!
    after very long day with a lot of traveling
    i cut 2 Pieces of perspex - for the door's windows
    and, it's fix!
    Screws for window, and the 5.25 bays.
    after welding the case - all i need is some paint...
    I chose the color from a catalog in a color factory , and after mixing the color - it was pressed into a can
    the layers:
    1. motip primer
    2.background color (blood red)
    3. main color
    4. motip lack
    motip primer
    after lack layer
    right - background , left - color
    paint job to the ram blocks
    with the OCZ original grill
    befor, and after
    that it for today, more updates will come soon,
  7. DonT-FeaR
    DonT-FeaR I know what a fk'n Dremel is ok.:D
    23 Jul 2008
    nice paint work
  8. arkadur
    3 May 2005
    thanks for the comment !:hip:
    another pics of the painting , as you can see, it's changing colors..
    welding 1
    welding 2
    color 1
    from other angle - a little gray
    one more
    5.25 bays
    inside
    the front panel connection bay
  9. ringo
    ringo What's a Dremel?
    14 Jun 2008
    Good paint shop and a really interesting project.
  10. arkadur
    3 May 2005
    another update
    first sketch with 0.5 pen
    very small radius corners
    starting the long drilling work..
    in the end
    and here i stopped with the doors.
    i cut the cases top for the radgrillz, and it's took a long time.. and a lot of cutting discs.
    as you can see, there is a little space in the top of the case,
    i can adjust it with a simple screw device, but i'll do that in the end of the assembly (when all the weight will be in the case)
    more updated will come soon,
  11. DonT-FeaR
    23 Jul 2008
    wow looking good.. side panel is nice
  12. arkadur
    3 May 2005
    update!
    i started with the WC assembly
    part 1 - clean the water blocks,
    so, i use the 355 pump
    open it
    and, change the top to the XSPC RES
    random lops with the parts
    some oil, and metal little pieces :
    out!
    without air bubbles
    some pics of the MB
    the case
    with the MB
    arcticlean!
    naked rams, for the ramblocks
    some storage HDD's..
    that it for today
    more updates will come soon.
    עדכונים נוספים בקרוב.
  13. automagsrock
    automagsrock What's a Dremel?
    18 Nov 2004
    Those Samsung Spinpoints I see there? :lol:
    Great job so far, looking great!!
  14. Richh999
    Richh999 Small Time Modder
    9 Oct 2008
    Wow.. Amazing work. What happened to the dominator ram?
    oh and I have one of those spinpoints, they're great.
  15. DonT-FeaR
    23 Jul 2008
    looks great !
    fantastic work mate
  16. arkadur
    3 May 2005
    thanks for the comments guys!
    a little update!
    some pics of the assembly..
    back
    front
    another one
    from the side
    blocks!
    last..
    thats it for today..
  17. DonT-FeaR
    23 Jul 2008
    that looks crazy!
    so many blocks! lol
  18. Connection|Closed
    Connection|Closed What's a Dremel?
    3 Nov 2008
    Any updates arkadur??
  19. IaKoVl
    IaKoVl What's a Dremel?
    31 Oct 2003
    the idiot forgot to update here (he updated in Israeli forums), there is an update but i'll let him show it
  20. arkadur
    3 May 2005
    pre-assembly
    wow...
    dont worry..i'm back!!
    its a little bit insane, but i've back to the Mozart case..
    i really dont know why...
    dual feser 360 at the back of the case
    side:
    i sow that one of the rads make me some problems with the psu cord,
    but i got a idea.. about the MB, it's block just the PS2 ports - that i dont need it anyway..
    the mcr 240 , in the case
    top
    mobo, and other parts assembly
    pumps, with the connection to the ex-rad
    from the outside
    useful mod...
    the other side of the case: the PSU
    as i said, the TFC rad, block the PSU cord
    so, i'll do this mod, all i need is to buy longer spacers..
    PSU cover
    ill remove the PSU stock grill,and install this one on the perspex
    sometimes, the liquid need to get out of the systems ,
    i got 4 loops, so that mean 4 drainage line
    inside
    outside
    thats it for today,
    i'm waiting to EK's tanks that will be place over the 655 pumps in the MB area
    about the 355 pump, maybe i'll place them under the PSU, or in the 5.25 cage.
    more updated will come soon..
    arkadur.
