Case Mod - Complete ⭐ Project Silver Mist
Discussion in 'Project Logs' started by SaaintJimmy, 2 Nov 2017.
  1. SaaintJimmy
    SaaintJimmy Staff Lover of bit-tech
    6 Apr 2016
    Hi folks! I'm back with a new project, this time based on a NZXT H440!
    It will feature a new kind of orientation, with unique custom feet and shape.
    In collaboration with: Aquatuning, Seasonic, Apacer Global.
    Let's start with some pics of the first modifications:
    I used this little trick with L-profiles to assure that the feet and the case were on level. This way I manage to get same exact height and mounting holes!
    This is all for now. Stay tuned for more progress! :D
  2. LePhuronn
    LePhuronn Minimodder
    6 Oct 2016
    I'm tuned, I'm SO tuned.
    SaaintJimmy likes this.
  3. SaaintJimmy
    6 Apr 2016
    Let's take a look at some gear from Aquatuning and Seasonic for the new project!
    From these reservoirs you can already see why I named the project "Silver Mist" :D
  4. galvinD
    galvinD What's a Dremel?
    6 Nov 2017
    Looks like it is going to be a neat build.
  5. SaaintJimmy
    6 Apr 2016
    Things are starting to take shape!
    Huge thanks to Gigabyte Italia for reaching out with this awesome Aorus X299 Gaming 3!
    Replaced the original fans/rads mountings with Phobya hexagonal grills:
    Blind nuts Cheesecake:
    First holes for pass-through fittings... on the feet?!
    Mounting the reservoirs
    Aorus X299 Gaming 3
    Fit test with radiators
  6. SaaintJimmy
    6 Apr 2016
    Making progress... today we have gas pistons for strenght on the structure and the first tubes that go through the case feet! :D
  7. SaaintJimmy
    6 Apr 2016
    I finally got some time to make some progress. Here is the res cover and the first layers of the side panels... "layers" because they're going to be three "sandwiched" little stripes of acrylic in which I will be able to slide the window itself!
  8. SaaintJimmy
    6 Apr 2016
    These are all the panels that will support the side panels... somebody once told me why it's taking so long to complete this mod! Well here's why dammit! :D
  9. SaaintJimmy
    6 Apr 2016
    Hi guys, I've been freaking busy lately and I didn't have time to update worklogs on forums. So here is a very big update!
    Completed the supports for sliding side panels:
    Strengthen the structure of the mobo tray and created an original vertical GPU mounting using L-Profiles. Also started to route the cables in the back:
    And a quick fit test:
  10. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    NZXT H440 is such a fun case to mod
  11. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Visually this is shaping up to be the best mod ive seen in a while, and your actually modding! amazing cuts and designs
  12. SaaintJimmy
    6 Apr 2016
    It's fun indeed! Even though it's a little harder than other cases, due to all those bends NZXT makes on the steel panels, in fact I had to cut so much stuff in order to fit some custom panels!
  13. SaaintJimmy
    6 Apr 2016
    Thanks man! I really appreciate these words :)
  14. SaaintJimmy
    6 Apr 2016
    I brought it home to finish the last panels and stuff and to paint and finally assemble everything.
    Side panels in the works, tubing spoiler and stands for the Cablemod RGB LED Strips. The end is near!
    neSSa likes this.
  15. SaaintJimmy
    6 Apr 2016
    Started the paintjob and final assembly, it's taking more time than expected but it will be finished soon! Silver and Inox effect paint :D
    (I moved outside to paint after the frame was done, those paints are hella glittery)
  16. Hukkel
    Hukkel James' minion
    20 Dec 2012
    I like where this is going so far!
  17. SaaintJimmy
    6 Apr 2016
    Thank you very much Tim! :D
  18. SaaintJimmy
    6 Apr 2016
    New update in the house: lower front side almost completed, feet mounted, back cable routing using a lazy but effective technique (hurray for the zip ties) and radiators painted in silver!
  19. SaaintJimmy
    6 Apr 2016
  20. LePhuronn
    6 Oct 2016
