Scratch Build – In Progress Project Simodd - 6 September
Discussion in 'Project Logs' started by Fifas, 6 Sep 2012.
  1. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    AWESOME build mate, I soooo need to get building my sim and I like the mods you done to your G25, my gearstick is getting slack so I need to strip it down and sort it :)
  2. Fifas
    Fifas New Member
    6 Sep 2012
    Thanks mate! :thumb:
    One more update :D
    Today I'm working on this:
    But It isn't working as I planned :blush:
    The serial communication isn't working that well, so the program in the video it's only a simulation.
    Also, the 7-segment display needs to be changed. I bought a Common Cathode one and the store send me a Common Anode. Only noticed when turn the board and the display went on holidays :D
  3. XNine
    XNine New Member
    10 Dec 2011
    Good lordy! Keep it up, this is fantastic!
  4. Fifas
    Fifas New Member
    6 Sep 2012
    Thanks mate! ;)
  5. Fifas
    Fifas New Member
    6 Sep 2012
    One more update!
    Changed the 7 segment to the correct one, a little programming, and the board is working! :)
    Did a quick video with my phone:
    More news soon :)
    What do you think? :thumb:
  6. that_du^de
    that_du^de give your head a wobble
    29 Nov 2010
    fifas the keys to start the car m8! so i can take it for a good thrash:thumb:
  7. Fifas
    Fifas New Member
    6 Sep 2012
    Oh...I think i get it now :blush: :thumb:
  8. Waynio
    Waynio Relaxing
    20 Aug 2009
    Nice addition. :D:clap:
  9. Fifas
    Fifas New Member
    6 Sep 2012
    Thanks mate! :)
    I'm designing a little case for the board now, and started the handbrake project :p pictures soon :)
  10. kinghong1970
    kinghong1970 Just a Clumsy Ape
    19 Apr 2009
    very nice build...
    i want to make one for my man cave...
    as for the mdf.. yea mdf + water kinda sux... there is sealed mdf that will soak up less liquid... for your future builds.
  11. Fifas
    Fifas New Member
    6 Sep 2012
    Thanks man :thumb:
    the new "base" was made using a "water resistant" MDF, that I really don't know the name :blush: But I really hope I don't need to test if it really is water resistant :D
  12. Fifas
    Fifas New Member
    6 Sep 2012
    Hey guys!
    So, yesterday i did some progress in the "extras" :thumb:
    Found this little box, and that gave me an idea :idea:...So started drilling
    And a little more dremmel work :dremel:
    Glued a switch in the inside with some PVC (This is only a prototype, so I didn't work in small details)
    The found this cable management tube...Perfect
    Cutted and drilled, and started assembling
    And finally...
    ..put some tape in it, just for the bling :D and boom. my new handbrake :D
    It's connected to an old gamepad board. I will make a nice PCB for it, and remove that cable coming from the inside
    What do you guys think?:blush:
  13. Sissilisko
    Sissilisko New Member
    26 Apr 2012
    it's still a bit rough looking but i believe in you that it will look great! :p
    one thing is bothering me, will it be strong enough if like you're friend or somebody will use force when using it like in real car?
  14. Fifas
    Fifas New Member
    6 Sep 2012
    Yes, this is not that good looking, but it's a "prototype"...
    It can take some force, but I will make it even stronger in a new version.
    Just one thing, this will be a "Rally Style" handbrake, next to the gearbox, not on the side of the seat :)
  15. Fifas
    Fifas New Member
    6 Sep 2012
    Sorry for the lack of updates guys. Just a quick update.
    I painted my "Handbrake Prototype"
    And placed it
    Tomorrow will likely post some final pics of the build. I want to make some new stuff, and update the hardware, but that will take some time, so I'm finishing here the project. Maybe later, when I get a job I'll make some updates.
    Thank you all for all the support! Thank you all for the MOTM nomination. I would not have done it without your support! :thumb:
  16. Fifas
    Fifas New Member
    6 Sep 2012
    Here are some final shots of the complete build. Hope you like it! ;)
    Only noticed the plexi off it's place in the photos :p Sorry
    One more time, thank you all for your support! Really appreciate it! :thumb:
  17. Fifas
    Fifas New Member
    6 Sep 2012
