Scratch Build – In Progress Project Slow
Discussion in 'Project Logs' started by Big_malc, 1 Feb 2012.
  1. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    Ok after 6 months better try and put some order to some pictures that have been posting.
    With lot of old bits floating around my pit and some stuff from work decided to build my self a Nas / small server (not decided yet).
    On Side note as everyone says this this is the first case I have ever try to build bit of a learning curve and alot of reading to be done.
    With a Quick chat with the powers that be a rather large sheet of 2mm stainless steel was aquired
    Plates cut down tacked and started to tig together cube
    Tig Welds sanded clean
    8mm Perf mesh cut to size
    Mesh and Fan Mount
    can you Guess what it is yet ?
  2. Sn00k3r
    Sn00k3r What's a Dremel?
    7 Apr 2011
    love that Hilti! :D
    Lookin' forward to this lil' Cube :cooldude:
  3. Mojo
    Mojo Multimodder
    18 Nov 2011
    Good start!
    Looks as if its going to be a Mini itx build? with a 120mm fan?
  4. KidMod-Southpaw
    28 Sep 2010
    Simple and cool- love it!
  5. peteski
    peteski long live the pc
    8 Jun 2011
    nice start mate. i like your skills :rock: :rock: :rock:
  6. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    Slow by name Slow by nature :D
    some little case feet been added
    MB plate marked out read for some more tapping
  7. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    a square line not something I am used to in my job
    A tile saw is a very hot method of cutting but when needs must
    Time to start some filing
  8. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    aluminium so much nicer than stainless steel but not as forgiving
  9. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    Time for a little Hdd mount for 2 drives 16gauge Stainless drilled and bent
    mmmm Shiny
    Two old drives mounted up for setting size
  10. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    Wonted to keep the Hdd tray and the MB tray as one so bit more marking and some M5 tapping sorry forgot to take some pics.
    cutting the M5 bolts down I nicked the MB plate but it wont be seen another one to put down to stop rushing and pay attention
  11. Big_malc
    Big_malc Minimodder
    7 Sep 2010
  12. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    Bad light and a cam on phone dont make good pics :p
  13. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    if I pull my finger out I might finish something started months ago :p
    few coats of white primer
    and a little bit of gray
    and a sneak peek of colour :p
  14. Ra6
    Ra6 What's a Dremel?
    4 Nov 2012
    That IS small! What a pack! It's impressive when every single centimetre is organized to fit properly! Great Job!
  15. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    :D thanks Ra6 could be about 70mm smaller but what you get for rushing and not planning.
  16. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    about 3 coats of orange
    5 or 6 coats :p lost count
    finished paining the orange
  17. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    The box of news paper and masking tape and a little bit of matt black
