Project: "SpeedFreak" UPDATE 24. aug
Discussion in 'Project Logs' started by CaPs_On, 10 Aug 2005.
  1. CaPs_On
    CaPs_On What's a Dremel?
    3 May 2005
    Hey!
    Well this is my first real self made project that ive started yesterday.
    Im haveing some problems with getting pics up, so just be patient cuz they will come. The specs is:
    Memory: OCZ 1024MB Premier Dual Channel
    PC-3200 2x512MB (2,5-3-3-7) 400Mhz
    CPU: AMD Athlon 64 3000+ 1.8 Ghz BOXED
    Socket 939 512KB cache "Venice"
    Mobo: DFI Lanparty UT NF4 Ultra-D hovedkort
    ATX/S-ATA/Dual-GB-LAN/8ch-LYD/1394/
    GPU: Club3d 6600gt 128mb pci-e 500/1000 stock.
    The hardware will be fan cooled in the begging because of lack of cash.
    Ive ordered:
    AcRyan 500mm*500mm 8mm acryl plating
    AcRyan 2*80mm blue uv fans with uv leds
    AcRyan SpeedFreak window etch/emblem
    The acryl plate will be replacing the whole side door because the original door went threw a 9" industrial grinder :D That was a bit of a misstake.
    The case has been taken a part and primed and colored with silk black.
    Updates will follow.
  2. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Sounds interesting.
    From the gear you have ordered I suspect you're either Dutch, or from Belgium. Correct?
  3. DaLoonie
    DaLoonie What's a Dremel?
    2 Aug 2005
    I'd give a shot he's from Denmark due to this word: "hovedkort"
    One of the many Danish words for Motherboard.
  4. ReFredzRate
    2 Sep 2002
    You win =/
  5. CaPs_On
    3 May 2005
    Hehe, non of you are correct actually :D Im norwegian and thnx for the replies an update will come shortly. Today perhaps.
  6. quadmodz
    quadmodz What's a Dremel?
    9 Oct 2004
    pictures please... :D
  7. CaPs_On
    3 May 2005
    Well you wanted pictures, here they are:
    just added the second coat of silk black:
    Just finished the other lot:
    The top done:
    And then the front wich i am VERY pleased with the result:
    More updates will come when i resive the rest of the parts.
    Thnx for all the positive replies.
  8. CaPs_On
    3 May 2005
    After painting the side door and the top of the case i discovered that the result today wasnt as pleasing as it was yesterday. the paint go a bit wierd in someway. but i think a 3rd stroke of paint will do the job.
    Ive just reseved some new parts to add up with:
    1. Lazer Led casing with 3 angled lazer leds. Blue
    2. Coolermaster aerogate 2
    3. Coolermaster musketer
    Im not sure if the coolermasters will go on "speedfreak" but i have some ideas that might work but ill get back to that later on.
    And yes, pictures will come later on.
    Cheers.
  9. CaPs_On
    3 May 2005
    UPDATE 24 aug.
    Well have made some progress since last time i posted.
    Got 2 80mm AcRyan uv fans and a 50cm*50cm cheet of acryl allso from AcRyan. Fitted the two fans and painted some slot covers.
    Front of the case:
    The new acryl cheet:
    And the window on the side door has been fixed and painted, and that is how it will be looking:
    More to come
