Case Mod - In Progress Project "Sulaco"
Discussion in 'Project Logs' started by tobyak, 30 Jul 2011.
  1. tobyak
    tobyak What's a Dremel?
    5 Jul 2011
    Time to do the casting
    What do we have
    • Resin
    • Catalyst
    • Mould
    • Mixing bowl
    • Mixing device
    Raw polyester resin
    Catalyst added
    Mixed, note the darker tone now, its an effect of the mix forming chemical bonds changing the structure, some of you will know this as "curing"
    this is a 100/1 mix ratio, resin to catalyst, but i am rounding up to the nearest gram, in this case 170g resin needs 2g catalyst, i weighed the amounts out before i started to save myself some time
    Sorry no pics of the pouring, the fumes liberated by the pour can mess up fine lenzes
    Pouring done
    As this is a one part mould you are going to get sunken and risen areas due to surface tension, so you may want to spread the top surface outside the confined ot the moulds sides to break that for a true smooth finish, this only applies to one part moulds where you are filling fight up to the top surface
    ITS READYYYYYYY!!!!!
    When cured you will notice its changed to a rather green tone and has some lateral shrinkage
    You will also be able to make out some hairlike marks in the surface, this is part of the curing process, where 2 curing areas meet they form this boundry line just like a continent
    A few of the finished items, on a block of alu to help dissipate the heat, as the resin whilst curing can get up to 80c
  2. tobyak
    5 Jul 2011
    All 4 parts cast, time to get the mouse sander out
    Here we see the mouse sander in its natural habitat, about to pounce on this basking bezel piece
    10 mins and a lot of swearing later (sanded my finger)
    30mins more and even more swearing (to annoy the neighbours)
    Ready to do the fine sanding ready to box up doe painting later
    Marcos_Viegas likes this.
  3. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    Excellent stuff fella! Keep it up :)
  4. tobyak
    5 Jul 2011
    Ile keep going till my dremel explodes...... then buy another
  5. tobyak
    5 Jul 2011
    Update coming later, its metal work day yay....... waits for applause..... oh no applause.... awwww
  6. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
  7. tobyak
    5 Jul 2011
    HAHAHAHAHA..... that has brigntened up my day
  8. Gentleman_Dingo
    Gentleman_Dingo What's a Dremel?
    30 Aug 2007
    Squirrel(prairie dog)! Look at what he did!
  9. tobyak
    5 Jul 2011
    MEMO TO SELF......
    Shout at Nzxt about the quality of there steel, an hour to make a 40cm cut. I dont rermember the discription for the Tempest EVO saying "made of adermantium"
  10. Marcos_Viegas
    Marcos_Viegas Minimodder
    6 May 2010
    Wow man... :jawdrop:
    You are realy a artist!
    Congratulations for your job! :thumb:
  11. tobyak
    5 Jul 2011
    WOW thankyou. I hope you enjoy the rest of my project once i get the latest shots uploaded
  12. BlancAnarchy
    BlancAnarchy What's a Dremel?
    15 Aug 2011
    p
    Awesome! Keep it up!!!
  13. tobyak
    5 Jul 2011
    New update as soon as my photo host decides it knows what a photo is
  14. Kylevdm
    Kylevdm The Mod Zoo Podcast Host
    4 Oct 2007
    Looking good dude! Has your photo host worked out what a photo is yet :p
  15. tobyak
    5 Jul 2011
    LOL yeah dude, all sorted, new pics uploading now
  16. tobyak
    5 Jul 2011
    Its door fabrication time, that means HERE COMES THE DREMEL yay!!!!
    First up, lets get this side taken apart
    Tabs off, lets pop the window out
    I will be using 1.5inch cutting discs from MNPCtech
    Measuring up the new window bezel and making sure my cut lines are marked well inside the cut.... CUTTING YAY
    Deburring
    Well that took ages lol, but the results are exactly what i need
    Next up, filling the acrylic for the window and starting the cut for the top mounting panel
    Unfortunately i couldnt get any shots of cutting the acrylic out as the dust was getting in my camera, co lets ump to filing and sanding the cut edge
    I will be using a rough sanding pad for this as i have a lot of material to remove
    Whoops
    Ahh there fixed, ther was never a huge chunk taken out of the edge... was there *swings hypnotists watch*
    In the next post... i start work on the top panel
  17. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    It's coming along great! Loved the inside info on the Casting :thumb:
  18. tobyak
    5 Jul 2011
    Cheers dude!!
    Casting can vary from easiest thing in the world to the biggest nightmare you have ever had, this is a relatively simple cast of a simple shape.
    Anythign can be case in tons of finishes, stone, marble, bronze, smoked, you can suspend objects in the mixture even transparent or translucent
    Anybody who wants to know more just ask me
  19. tobyak
    5 Jul 2011
    Busy week, children, fabrication, deliveries, the list goes on....
    Finialy an update and i am delighted to say it is a sponsor
  20. miahallen
    miahallen Team IRONMODS - World Champions!
    5 Sep 2010
    Congrats on the sponsorship :thumb:
