Case Mod - Complete Project Taurus - A first timer's ambitious competition entry
Discussion in 'Project Logs' started by Arman Esma, 11 Oct 2021.
  1. Arman Esma
    Arman Esma Custom PC Cebu
    11 Oct 2021
    Hello,
    I built this PC for a local (Philippines) modding competition and decided to showcase it here as well.
    This was my first time doing a custom loop, soldering LEDs, CAD Modelling, 3D Printing, working with acrylic and weathering so I had a limited time to learn everything. My competitors were mostly professional modders that knew all these things like the back of their hand so I had a lot of work cutout for me.
    Some of the guidelines for this build that I set for myself were:
    1. Color: Black and White
    2. Theme: Sci-fi
    2. No permanent modifications to the case
    3. Mount the GPU vertically and be able to use at least 2 display outputs.
    Jean R built and Cheapskate like this.
  2. Arman Esma
    11 Oct 2021
    Here's how it looked before any mods were done.
  3. Arman Esma
    11 Oct 2021
    This is the Asus ROG Strix x570-i, HyperX 32GB (2x 16GB) 3200MHz that I decided to paint white. The cooler in the pictures is a Thermalrite FS140 that was later changed since I decided to go full liquid cooling.
  4. Arman Esma
    11 Oct 2021
    I made 2 versions for the case feet that needed to be tall enough to accomodate the cables but sturdy enough to hold the weight of the pc. The first version was a flop since it bent after a few days.
    note the use of a GT 730 so I could still use the PC while working on the mods.
  5. Arman Esma
    11 Oct 2021
    I designed the LCD mount to screw into the HDD that's also screwed into the PSU. The LCD shroud is made of acrylic and had to go through a few revisions. I used rainmeter to show the stats on the display.
  6. Arman Esma
    11 Oct 2021
    When I started this build I didn't expect to go full custom waterloop but I saw an ad on FB Marketplace for an Asus EKWB 3070 that he wanted to trade for something else so I offered him my already painted in white plastidip Strix 3070 and he accepted in a heart beat. This then forced me to go full custom loop with only about 2 weeks left in the competition.
  7. Arman Esma
    11 Oct 2021
    The liquid cooling parts arrived with about a week left in the competition so it was definitely crunch time for me, I went straight ahead into masking and painting the CPU Block and radiators.
  8. Arman Esma
    11 Oct 2021
    After a few videos on bending acrylic tubes, I started my first bend on a tiny 90 degree from the cpu block to the radiator. I had to move the radiators all the way up to where I couldn't screw in the top 2 holes so that it would be a straight 90. The bend after that was a very ambitious 4 bend running from the bottom left radiator to the top right radiator.
    At the same time that I was bending the tubes, I was also designing and printing the external parts of the pc.
  9. Arman Esma
    11 Oct 2021
    Got to have that RGB goodness.
  10. Arman Esma
    11 Oct 2021
    Final Pics
    Would definitely appreciate some feedback so feel free to comment down below.
    neSSa and pccustom like this.
  11. Cheapskate
    13 May 2007
    Quite nice. :thumb: Welcome to bit.
  12. Arman Esma
    11 Oct 2021
    thanks my dude. :)
  13. Ragster
    Ragster What's a Dremel?
    27 Aug 2021
    Incredible work! First time build here too- did you eyeball those acrylic bends or use jigs? They look super clean.
  14. pccustom
    pccustom Multimodder
    12 Jul 2017
    great!
  15. Arman Esma
    11 Oct 2021
    Thanks, I used some plastic jigs from Bykski but I wish I had built my own out of plywood or something since I saw somewhere that they would come out even tighter.
    Ragster likes this.
