After fighting of my teachers on the subject of coursework i decided it was time i started modding my pc here is what i have done so far i started of by cutting a window in the side with a jigsaw-updates comeing soon please comment on anything (yes the picture is very big i just got my ftp running though so i have ad not mauch time to edit it)
That red tinted "X" style window on the white side panel goes well. You said the pic was big, it's only a few pixels across..... * Sarcasm mode off That's better... I can see it now. Nice simplistic window. I like straight edged windows personally. Remember to tidy the edges up
I was actually playing on the fact that I could only see a small white page with a red cross on it. I had to copy and paste the filename into the address bar to see the file
please edit your image to be this address... it allows outside linking and is scaled down to an appropriate size.... http://users.wpi.edu/~cderalow/images/other/hosted/PC230259.jpg
the time is now modders.net have helped me out! after painting it did not fit together properly so im not sure if this should go in the disaster mods! here is an overall picture of it: the other side: close up with colour fan on: here window side without flash also my other mods include a: blowhole: and a fan switchboard wich i soldered the wiring for inside an dmy hands are covered in plasters from burns (damm caffeine)
The paint looks pretty uneven and your blowhole could do with a bit of a tidy with a small file, but other than that it looks cool. I like the colour, and the toggle switches look smart
It's pretty good for a first mod. I wish my first mod came out that way. ( My window was a little off center. )
