Project: the **Bunker**
Discussion in 'Project Logs' started by quadmodz, 27 Aug 2005.
  1. quadmodz
    quadmodz What's a Dremel?
    9 Oct 2004
    I did that curve and I will sand it to have more curve. Because I will put some effects there.. :D
    thanks bro!
  2. quadmodz
    9 Oct 2004
    Here's what Ive done for today... I place my reservoir on my top panel.
    I've got a big problem on my screws because its too short. :waah: So for the mean time I'll use this screws first as you've seen on the picture.. :D
    First Heres my top/front panel of my case.. :D
    Here's I've did................
    :D
  3. Payne280
    Payne280 What's a Dremel?
    19 Oct 2005
    looks good but i'm not really a fan of that reservoir
  4. quadmodz
    9 Oct 2004
    Here's the case that I will work on...
    I used aluminum angle bar to lock it..
    with the help of this rusty metal scissor. :hehe:
    Need to sander those curves. :D
    And the result... :D
  5. quadmodz
    9 Oct 2004
    Time for some updates... :D
    Now, I change my plan for my pump.. I want to make change of the figure.. anyway just look the pics.. :)
    Here are some materials I used.
    Next, prepare for bending
    For the next side :D
  6. quadmodz
    9 Oct 2004
    I use this card board for the bending...
    Time for bending again.. :D
    :D
    I need to cut some extra edge
    TOP VIEW...
    That's it.. I'll make some hole for the barbs tomorrow... See yah! :D
  7. Zyche
    Zyche What's a Dremel?
    16 Sep 2005
    Kababayan! may i ask where u bought your dremel?
  8. Echo
    Echo What's a Dremel?
    10 Oct 2005
    Nice bending skills there :p
    Looking really good! Keep it comming!
  9. RR5
    RR5 What's a Dremel?
    7 Dec 2003
    Oh no pictures do not load on page 3. Good work man!
    -edit do not view bit tech while at work.
