Project TreasureChest - DEAD....Check for Project "The Core" in the near future
Discussion in 'Project Logs' started by Sozialcyke, 26 Feb 2003.
  1. Sozialcyke
    Sozialcyke What's a Dremel?
    18 Feb 2003
    Well, I finally finished my design for my new case. I call it, the lunchbox...
    Entire case is built from Plexi-glass. There will almost definitely be more fans in the case, along with etching/lighting. Right now, I plan on using a UV CCL to highlight somethings on the board. Plan on doing the UV drawing style shown here
    Any questions? Comments? This is going to be my first mod, so I may need some help. Tell me what you think
  2. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    Tasty...
    ...sorry
  3. Moreland
    Moreland banned
    16 Jan 2003
    that looks really nice :D you thinking of actually making it portable? so you can use it at lunch, or is the name just because of the shape and style?
  4. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    /me likes the design... the fans at the top are at optimum position, I assume one sucks and the other blows?... I just ordered a load of uv reactive acrylic from delvies... should be here today/tomorrow.. getting itchy to use it, looking forward to seeing this project progress.
  5. acrimonious
    8 Nov 2002
    Is it going to be made out of clear acrylic or is that just an effect you've put on so we can see inide the design?
  6. Sozialcyke
    18 Feb 2003
    It's going to be clear acrylic, so that you can see the mobo circuitry light up when the UV light is on. It's an ATX mobo, so I didn't design it for portability. Also, forgot to mention that I plan on windowing the HDD and CD-RW.
  7. zackerouac
    zackerouac bring it
    23 Sep 2002
    lunchbox after kevin smith? or just cause of the design? either its gonna be cool :D
  8. complexprocess
    complexprocess What's a Dremel?
    8 Jul 2002
    If that's a full atx motherboard, maybe you should consider calling it Project Treasure Chest. :lol:
    Looks like it will be very cool.
  9. penski
    penski BodMod
    29 Aug 2002
    My only concern is how readily the PSU will be able to get air for cooling...
    Is it going to exit fromt he side underneath the mobo?
    *n
  10. War-Rasta
    War-Rasta What's a Dremel?
    22 May 2002
    looking good! :lol:
    are u going to leave it all clear?
    perhaps u should think of doing som painting Macroblack Style.
  11. fivecheebs
    fivecheebs Dont panic!
    19 Feb 2003
    That UV highlighting mod reminds me of Tron!! I like it tho.
  12. Sozialcyke
    18 Feb 2003
    Acrylic Question
    Okay, I got some money to put towards this project now :D . I was wondering what the best thickness of Acrylic sheets to use would be. I have to bend the acrylic in a half-circle, so I'm not sure if creases would be that big of a problem.
    I was thinking of going with the 1/8th inch.....Any comments on this?
  13. hydrogen18
    hydrogen18 Banned
    19 Jun 2002
    1/4th inch is extremely rigid and strong, if u are an absolute strength freak go for 3/8 inch(but be warned it is HEAVY). 1/4th can be bent, but takes ages to heat each joint and u have to use a low heat to avoid bubbling and such. 1/8th is best for bending, but with ure curves, I suggest using casting resin or vacuum forming(I have no experience there, but it seems most logical)
    btw, if that is an extended atx mobo, this should be called project plexiglass casket, as it will be fecking huge
  14. djengiz
    djengiz Pointless.
    16 Aug 2002
    Nice, cant wait for the project log
  15. Sozialcyke
    18 Feb 2003
    Modified Project - 3/5/81 (Happy B-Day to ME!!)
    Well, as part of my b-day present to myself, I've decided to scrap this project and start a new one. The case design is up in my head, but not on "paper" yet. I won't give away my idea yet, except to say that it will have water, but won't be water-cooled :)
    I'll post a pic of my design within the next couple of days under the project name "THE CORE"
  16. zackerouac
    zackerouac bring it
    23 Sep 2002
    happy b-day :D now get to work!! :D
  17. jethro
    jethro Modthusiast
    19 Mar 2002
    that is a sweet degisn, cant wait to see come real picts...
  18. Sozialcyke
    18 Feb 2003
    Unfortunately, Jethro, that case design has been scrapped. I have a new one in my head. Getting it down on paper right now. Will post pics of my idea as soon as they are done....Will probably start a new thread though...
  19. War-Rasta
    22 May 2002
    judging fot what u've said it sounds interesting.
    waiting for the thread.
  20. daydreamingknight
    daydreamingknight What's a Dremel?
    9 Jun 2002
    I'm also looking forward to it!
    DDK
