Case Mod - Complete ⭐ Project Trinity
Discussion in 'Project Logs' started by DeZoTriX, 11 Jul 2019.
  1. DeZoTriX
    DeZoTriX What's a Dremel?
    7 Nov 2018
    There's always a next time! :D
  2. kim
    kim hardware addict
    10 Jan 2016
    very elegant build, frosted tubes and res, color sheme, designed parts, everything is so beautiful and clean...I just allow myself to quote Cheapstake, you 've done such a no-compromise job here, I am pretty sure you could easily design a small cover for that blue spot of the PCI riser...
    DeZoTriX likes this.
  3. scuppy
    scuppy Minimodder
    26 Apr 2011
    This looks AMAZING!! I don't quite understand how the GPU was mounted though - This is something I have looked into with my TJ07 but I don't want to use a replacement PCI cage that takes up all of my regular PCI slots.
  4. Sa mod pc design
    Sa mod pc design Minimodder
    7 May 2019
    Awesome work
  5. DeZoTriX
    7 Nov 2018
    Thanks for the kind words :) Yes, I guess I failed to go to the last mile, but it's a easy fix.
  6. DeZoTriX
    7 Nov 2018
    Hope this helps, it's pretty much only attached to the case with screws and a cutout for the output cables.
