Case Mod - In Progress Project : Turtle Rig.
Discussion in 'Project Logs' started by polished skull, 30 Nov 2007.
  1. polished skull
    polished skull mini modder
    7 Aug 2007
    Hi all,this my 2nd personal modding at Bit-tech.net.
    I Bought an old skool case from a friend and i realized that the casing have a great potential to be mod.
    The problem is,im limited of ideas,thats y i post a new thread to share with u guys and give me some ideas.
    This is gonna be a real simple mod.Im trying to make is slow because short of fund and tight budget.:miffed:
    Orite,lets get it started.:dremel:
    The plans are:
    * Create a 120mm intake at the front.
    * Make a square hole at the bottom part and place a acrylic transparent.
    * repaint the inner part and the whole case.
    * Do some cable management as im not using a modular psu.
    * Install a case feet.
    * Change the front panel into a custom made front panel.
    * others will come later.
    The side view of the case.
    The top view of the case.
    The front side of the case.So damn old skool.
    The view from right side.wavy side panel.
    Lastly,the back side of the case.Only support 1x 8cm exhaust fan.:waah:
    I will upload the interior parts later after i dismantle all of the into pieces.
    Ideas are mostly wellcome.
    Thanx guys.:thumb:
  2. doubble_d
    doubble_d mystery box
    21 Nov 2007
    hey man taths a cool case.... keep the fronr cuse i like it.......// doubble and mystery box 2.0
  3. Gumbatron
    Gumbatron What's a Dremel?
    18 Nov 2004
    As soon as I saw that case I thought it'd be a case that DÈF¥âÑt¸.·´¯`¤ would have a lot of fun with. It's got some potential there. I'd say the best thing you could do at the moment it to have a look around at other peoples mods, particularly ones that involve curved and flowing surfaces. It'll give you an idea of what the possibilities are. Then it's really up to your imagination.
    Here's a start. Have a look at this case: HPR-4 Flame'D
  4. polished skull
    7 Aug 2007
    Thanx mate.The front panel is cool tough.
    But the big deal is,if i maintain to keep the front panel,it must go with the sode panel and top panel too as the curve
    part make its hard to be mod.
    hope you get it.Maybe ill use some bondo work if i want to keep using the original front panel.
    Thanx Gumbatron,
    i love the work,he's awesome and creative.Great ideas bro.
    It inspires me.:clap:
  5. polished skull
    7 Aug 2007
    For this mod,is it sufficient if i make a 1 120mm for intake at the front and another 80mm exhaust at the rear ??
    This case is so small,i plan to make better airflow case that can keep up my X1950XT working below 90c. :sigh:
  6. polished skull
    7 Aug 2007
    Here some small updates.All the parts are taken out into pieces to start the mod.:dremel:
  7. polished skull
    7 Aug 2007
  8. simosaurus
    simosaurus What's a Dremel?
    12 Jun 2005
    NOooooo, dont ruin the front with a big ugly intake!
  9. lworbey
    lworbey What's a Dremel?
    23 Nov 2007
    Wow, Ive not seen a bought case quite that curvy before, should make a great mod, I'll look forward to seeing how this one goes!
  10. polished skull
    7 Aug 2007
    The front panel will be replaced using an acrylic.Maybe im not gonna use the original front because its too bulky and huge.
    But im not sure how to make a 5.25" and 2.5" bezel.
  11. polished skull
    7 Aug 2007
    Thanx bro..its an old case my fren gave me. time to pimp it .
  12. dan-ere-07
    dan-ere-07 What's a Dremel?
    29 Mar 2007
    Turn it into a dragon lol
    the wavey parts on the side look like dragon wings
  13. Scirocco
    Scirocco Boobs, I have them, you lose.
    3 Jul 2007
    That is a perfectly ooogly case! This should be a fun mod. Good luck and I'll be watching.
  14. polished skull
    7 Aug 2007
    Thanx bro.The wavy side panel wont be used as i will only use the steel panel and will put a raddy IF im using WC.
    Thanx to you too.
    I hope it will be fun,rite now,im still deciding the front panel.Not sure either gonna use rivets or just screws to stick an acrylic to the front panel.
  15. polished skull
    7 Aug 2007
    Whats is the perfect color to use??:worried:
  16. Jewno
    Jewno industrial designer
    4 Feb 2004
    green?
  17. polished skull
    7 Aug 2007
    Any other colour? Im using RED CCFL :thumb:
    I want it to look soft,cool and at the same time also look fierce.:D
  18. polished skull
    7 Aug 2007
    2/12/07 : Ventilation Design Updates.
    This is some edited photos of the layout.
    The square part at at the bottom part will be cut and be replaced with mesh,grill or just a plexi ( acrylic).
    The rounded 80mm will be cut to make full air to flow out from the case.
    The small square part next to the PCI slot also will be cut to put some mesh,grill or just a plexi ( acrylic).
    :cheers:
    Ventilation For Top Panel.
    Two 120mm Intake at the top
    OR
    Just put 1X 120mm Fan on top.With two square holes for mesh,grill or acrylic.
    Front panel ventilation.Its a must :thumbs:
    This part ill just make it simple by cutting a 120mm hole for an intake.Ill add a 120mm blue LED fan so its still canbe seen clearly from the front panel. :thumbs:
  19. polished skull
    7 Aug 2007
    4/12/07 Small updates on the panel that need to be cut.
    I am not gonna cut it 1st as i still need a perfect design for it.This just an example of the side panel where i cover those 5.25 bays and also the power supply.
    Any other design are mostly wellcome..:thumb:
  20. Cheapskate
    13 May 2007
    You could cut a big square out where that 80mm hole is in the back and make a duct for a 120mm that blows directly onto your mobo...
    It you do make a hole in the front- I say keep the original front and sculpt the blowhole to match the design. Or cut out the bottom of the frontpiece and leave the fan unexposed. The fan should give the plastic an eerie glow.
