Case Mod - Complete ⭐ Project: Venom (Define R6 Mod)
Discussion in 'Project Logs' started by MT. Mods, 11 Dec 2017.
  1. MT. Mods
    MT. Mods Case Modder
    6 Apr 2016
    Hello and welcome to the project logs for: VENOM
    First i'd like to thank all the wornderful people who helped with this project
    Cablemod (Link)
    ASUS Republic of gamers UK (Link)
    TeamGroup Global (Link)
    Fractal Design (Link)
    EK Water Blocks (Link)
    Cablemod being the main sponsor for this project also paid for nearly everything on this project.
    the awesome saucy team that they are :)
    Specs:
    Cablemod Pro Edition Cable extensions
    Cablemod RGB/UV LED Kit
    Cablemod RGB/UV LED strip 30cm
    Cablemod green thumb screws
    Ryzen 7 1700X
    ASUS ROG Crosshair VI Hero
    ASUS ROG Strix 1070
    Fractal Design Meshify C
    Fractal Design 850w PSU
    Teamgroup Global RAM (Cannot discuss at this time)
    EKWB Full watercooling
    EK-Vardar EVO 140ER Black (2000rpm)
    EK-CoolStream SE 280
    EK-FB ASUS C6H RGB Monoblock - Nickel
    EK-HD Tube 10/12mm 500mm
    EK-HDC Fitting 12mm G1/4 - Black
    EK-RES X3 150
    EK-XTOP Revo D5 PWM - (incl. pump)
    EK-CryoFuel Acid Green Premix 900 mL
    EK-AF Angled 90° G1/4 Black
    EK-AF Angled 45° G1/4 Black
    EK-FC1080 GTX Strix - Acetal+Nickel
    EK-FC1080 GTX Strix Backplate - Black
    What is VENOM ?
    Venom is an all green and black build, with a serious twist.
    using PolyMorph plastic, i'll be re-doing the shroud and panels of the case.
    Veins will be wrapping themselves around the whole case and internals, these veins will ignite bright green under UV lights.
    Think of the upside-down in Stranger Things.
    Imagine those roots/veins as green.. Got it? lol
    I've got a lot of work ahead of me on this one, i'll also be doing strange things to the tubing, reservoir and fittings.
    It's actually very hard to describe, but i got all the design images i need up in my brain lol.
    Photo's
    Delivery from Cablemod!
    I had these cables custom made just for this project.
    These are the Cablemod Pro cables, with Aluminium combs
    I also asked for some sexy Anodised thumb screws from cablemod
    And finally, i needed some UV lights for the project.
    Cablemod sent out RGB/UV kit + extra 30cm strip
    Delivery from ASUS Republic Of Games UK - Has just arrived!
    Check out these two beauties!
    First up is the Crosshair VI Hero!
    Next up, the Strix 1070 OC 8GB
    That's all for today folks.
    Thanks for looking :)
  2. idpcmods
    idpcmods Minimodder
    30 Jun 2015
    stop teasing ;)
  3. MT. Mods
    6 Apr 2016
    Haha.. Won't be long now.
    Work should commence in the next couple of days :)
    idpcmods likes this.
  4. MT. Mods
    6 Apr 2016
    Work is well and truly under way.
    So, i got my polymorph in yesterday and begun working on the shroud + Roots + added a new alien monster thing (in progress)
    Polymorph is ugly to look at in it's raw state, however when painted, it completely changes everything.
    PolyMorph Raw after moulding into shape.
    After painting with a gun metal grey
    I then filled the little caves/holes with UV green paint (dries clear) to give it that extra coolness.
    Next up, i begun working on the jaw bones and teeth of the alien monster
    I first shaped the teeth, then stuck them onto a curved piece of polymorph as the jaw structure.
    i then tipped each tooth with clear UV green paint
    After this, i painted the jaw, and re-attached the teeth
    And then under UV light for testing
    i do want to show you more, but i can't without breaking some kind of rule i'm under :p
    Check back tomorrow for more details
  5. MT. Mods
    6 Apr 2016
    NDA has been lifted and i can now say.. I lied to you all.. I'm not using the Meshify C :p
    Say hello, to the new Define R6 from fractal design
  6. MT. Mods
    6 Apr 2016
    Here's some shots of the new Fractal Design - Define R6
    And now, some progress on the case mod.
    This is a video, of how i accomplished the shroud effect, using polymorph. :)
  7. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    I'm following this project.
  8. MT. Mods
    6 Apr 2016
    Thanks, :)
    Just waiting for the EKWB parts to arrive, once in i'll be able to move forward with the next few stages :)
  9. MT. Mods
    6 Apr 2016
    EK Water Block watercooling has landed, and is looking FIIIIINEEE!
    Check out some photo's here!
    (Will try get these re-sized tonight, not sure why they're so big)
    Special thanks to the wonderful team over at EKWB
    Beautiful watercooling parts, beautiful way of working with people like me.
  10. MT. Mods
    6 Apr 2016
    Some progress updates.
    I've been working on the loop, followed by the polymorph.
    Have successfully managed to get the polymorph on the tubing, reservoir and monoblock.
    Will smooth down tomorrow, as it's running late here.
    First an image of the monoblock, and EK's Cryofuel Acid green coolant!
    And... how it looks now
    Will update some more tomorrow :)
  11. MT. Mods
    6 Apr 2016
    So, i've been busy busy, keeping my mind occupied.
    Managed to make a huge start on the polymorphing.
    So... here's some Weird ass photo's lol.
    Here's where the Cablemod Thumb screws were used.
    [​IMG] #
    And finally, i'm going back over all the uneven areas, heating them up and re-moulding them all properly.
    Looks really weird when it's hot and sticky lol
    More to follow
    - Craig
  12. _Prometheus_
    _Prometheus_ Minimodder
    2 Jul 2017
    What hell is? :jawdrop:
  13. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    More art than modding?
  14. MT. Mods
    6 Apr 2016
    Finally managed to get some very near completed photo's.
    Waiting for the glass window to come back, all etched and pretty!
    WIll update as soon as i get the window back :)
  15. MT. Mods
    6 Apr 2016
    Hello everyone!
    Change of theme, slightly.. :p
    Seen the new venom trailer, and decided to go full marvel venom.
    So... started with the front panel and repainted everything matte black.
    Drew up the idea.
    Added more polymorph and etched out the design on the front custom panel.
    Then it was time to add some more venomy looking stuff inside, and backlight that front panel.
    Here's a photo of the panel before it was cleaned up
    And once cleaned up
    Thanks for looking, final photos to come :)
    - Craig
