Scratch Build – In Progress Project X-343B-WC [Lian Li Cube Watercooled]
Discussion in 'Project Logs' started by mjassbong, 12 Jul 2007.
  1. mjassbong
    mjassbong What's a Dremel?
    12 Jul 2007
    Sorry but which clips?
  2. mjassbong
    12 Jul 2007
    After posting this log I realized then that it may not be in the appropriate forum. You can find and see my comment that followed the log. Initially I take no offense at all from you until your final comment. Mind you, this project took more than just a one or two minute cuts. It was more like 3 to 5 minutes.
  3. mjassbong
    12 Jul 2007
    Thx! :)
  4. mjassbong
    12 Jul 2007
    Mod, please move this to the appropriate forum or completely delete it from here. Thanks!
  5. SPQQKY
    SPQQKY Evil Modder
    7 Jul 2007
    LOL....minute.....as in, minuscule
    .....damnable English language. :thumb:
    Cheers and happy gaming.
  6. kickarse
    kickarse What's a Dremel?
    6 Oct 2004
    You're so smart... ^^ ... perhaps you should be a linguist. :rolleyes:
    My simple thought was that he might have changed his mind from ONE post. People do have a habit of doing that you know and they don't need to be berated because of it. It's possible that, yes, he might have put it in the wrong area to begin with but as it turned out he figured he might do more at one point in the near future. :sigh:
  7. SPQQKY
    SPQQKY Evil Modder
    7 Jul 2007
    I don't know what your problem is, pal. Send me a PM if you wanna continue to gripe.
  8. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    badass system bro. Too bad you'd probably have the same performance with two loops and dual BIXII's. I gotta hand it to you though, that's exactly what I thought of doing when I first saw that case (except the cpu loop would be phase change)
