Project X1 (Updated Nov 3)
Discussion in 'Project Logs' started by agent orange, 2 Jun 2004.
  1. agent orange
    agent orange What's a Dremel?
    8 Dec 2002
    This morning was like christmas, except this time there was presents for me! Both of my shipments arrived on the same truck.
    Some piccies:
    even cats like the stacker.
    Excuse the qality of my pics.. I have this half-assed "pocket" digital camera, with no zoom or focus... and it kind of randomly decides what's in the frame and what's not...
    Anyway, I'll be testing out some configurations, and playing with some mod ideas....
    Til next time.
  2. agent orange
    8 Dec 2002
    So, it looks like I'll be mounting the rad at the bottom of the case. I was hoping the top PSU rack would allow enough clearance for the rad, but it looks like that's not the case, which means I would pretty much have to remove the whole cage. maybe if I can find a shroud that isn't so tall... mebbe one of those acrylic ones from voyeurmods.
    The good thing about this is that there's a grill on the bottom of the case already, so airflow is taken care of, I just need to mount the rad somehow.
    here's some piccies:
  3. Soulfly22583
    Soulfly22583 What's a Dremel?
    12 Jan 2004
    So did you get a cat with your new case? that must of been fun to open the box and find that :thumb: :naughty: :D
  4. 3.5SE
    3.5SE What's a Dremel?
    21 Nov 2003
    That's an awesome mod man. How'd you get the cats a$$ and tail to stick out the side of the case like that? Sweet :dremel: :hehe:
  5. agent orange
    8 Dec 2002
    Lol... yeah, it makes my case run at like 12Ghz... That's right, my case.. and you should see the processor... 1337!
    I'll be starting the modding soon. This is just the start.
  6. Nath
    Nath Your appeal has already been filed.
    28 Dec 2003
    I really like the case, never seen a design like that before, and I'll really be interested what you can do to improve it. I'm subscribed :thumb:
  7. agent orange
    8 Dec 2002
    Here's a PS mockup of the applique idea I had...
    I sent the design to jesse@bigfoot, so we'll see how it goes.
  8. Zion
    Zion What's a Dremel?
    11 Apr 2004
    I really like the case you got it shows a lot of potential as a killer mod. I especially like the window Iidea in the mockup, how are you going about doing that design? Plus I didn’t see what kind of case it is?
  9. Go4t
    Go4t i
    13 Dec 2003
    its a coolermaster cm stacker
    did you get the cross flow fan with it?
  10. bushd
    bushd What's a Dremel?
    9 Nov 2002
    Well, if that is a window I spy, you could try your hand at dremel and LED work, etching out that pattern, and using leds to light it up.
  11. agent orange
    8 Dec 2002
    go4t is right, it is in fact a CM stacker... one of the first 2 in Canada, in fact. :rock: As for the window, I'm going to be tinting it and jesse@bigfoot computers will be doing an applique in silver for me for the PCB pattern. I haven't figured out the top yet, but I may put one there, too.
    I guess I should update with some stuff I have in the works:
    PSone LCD for the front.
    Covering te multipanel with some kind of door.
    the window(s) -tinted
    mounting my 2X120 rad somewhere... still not sure
    red led's in my RBX and chipset block
    That's all I can remember now... :duh:
  12. naelq
    naelq What's a Dremel?
    14 Oct 2003
    sounds promising! :thumb:
  13. Prophet
    Prophet Minimodder
    19 May 2003
    Looks cool, those appliques look nice, would look killer with the actual circuit wire parts lit up!
    Proph.
  14. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Ooooh!!! Love the applique idea!! :eek:
  15. agent orange
    8 Dec 2002
    Haven't been working on this much, been working and breakdancing a lot lately :rock:
    I'm re-working the esthetics of the case, and the functionality of the cooling.
    I've got a sketch of what I want to cut into the side panel and top. The window will still be tinted, but the top 2 have been added, and will be done in black modder's mesh, to allow fresh air to come in from the side, and out the top.
    I'm also working on the design for a peice of plexi to isolate the PS and HDD's from the rest of the system (a la the new Lian Li's)
    More to come...
  16. Nath
    28 Dec 2003
    Have you got any idea what you're gonna do about dust? the mesh let's a load of the stuff through and it'll clog up fans like nobody's business....
  17. Nexxo
    23 Oct 2001
    New log, new case, new fun
    Yea! :rock: :rock: :rock:
    Looking good already! But I would have the small mesh side window at the bottom, not the top, to allow cold air to travel all the way up the case and create a convection current.
  18. agent orange
    8 Dec 2002
    Yeah, the original coolermaster window has a big filered opening, so I'm going to use filter from that on the side, so that that's not a problem.
    Also, here's the Idea I had to Isolate the PSU and HDD's (they make a lot of heat) from the rest of the system:
    should work fairly well, the floppy will be above the partition, because that's how the cage sits in the bottom. I'll probably cut a hole in the plexi near the front to route the cables.
    More on the way.
  19. Jang
    Jang What's a Dremel?
    3 Feb 2004
    Sorry if this sounds a little stupid, but heat travels up so surly the HD's and psu etc would be best at the top?
    I really don't have a clue do i :duh: :blush:
  20. jezmck
    jezmck Minimodder
    25 Sep 2003
    you're right about heat going up, but if there's enough air-flow then it won't matter much.
    would like to see how this case turns out...
