The shape of the window is looking nice! Abiout the "Y2" logo....why don't you use a rair font / other than that!? I don't like it myself. Go for a extreme font or a carved one. Case is looking fine though. ~Xeno~
Still havent started cutting this case yet, need to get my arse into gear. Window design is finalised, wont be doing the y2 logo. The front bottom bezel will also be replaced with black mesh (Pug style, but not as neat) I'm actually finding it hard to come up with anything original thats not over the top. I'll get most of the work done on this one over the coming week or so, just to get the PC back in a case. My main problem now is that I really want to build a complete custom case. Just need to find cheap 4mm plexi.
Sorry for the lack of updates, not had the time recently. The outside of the case will remain silver, whilst the chassis will probably be painted black.
My hosting has went down, reported it to domainbusters but still nothing. I'll move them over to my other domain when I get the chance. Ohhhh this was the last one in the shop, w000t. More eye candy Also found an excellent wiring guide by our very own bee2643 http://www.kickassamd.com/modules/mods/article.php?storyid=1 Edit, quick power up test, w00t it works.
OMG! I have that case. And that kit. (But with metric fittings) And was wanting to put a PsOne LCD in that case. And I was planning on using really fine gauge grey mesh for a window. But now if I do that I'll be copying you almost exactly! Looks good so far though, btw.
That PS1 screen is going to be sweet! On the cooling side of things what effect does the extra rad have on the temps? Does it reduce the flow very much?
It will if I get it working properly Havent noticed an improvement with the second RAD. Toying with the idea of running a dual watercooling setup, one for CPU and the other for CPU and NB.
The pressure drop will probably negate any increased cooling - although 8Ball or Pug would know either way. A twin system isn't out of the question, its not like you haven't got enough room Would u use th 80 for the gfx and nb?
Nice windows, are you going to put molding on them? If I was you I wouldent, i think molding looks bad and makes it look like to much of a premod. But each to his own. I like the screen
No moulding, plus the window will be black mesh not plexi anyway. Probably have a plexi window on the mobo side, but it will be done macroblack style.
