Displays [Projector] Sync Out Of Range Error
Discussion in 'Tech Support' started by deathtaker27, 12 Dec 2010.
  1. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    Hey guys,
    I have got a bit of a problem with a projector that I use, it is a hitachi CP 830 E and everytime I try to connect a notebook to it, it comes back with view sync out of range.
    Things Tested:
    Lower Resolution (800*600)
    RGB 1 and 2
    none of these work, and before you ask yes the notebook vga port works as it also connects and works on 3 screens which are connected to the system.
    Would be nice to get this sorted, else I will have to go with my backup plan :/
    Thanks in advanced
    DT
  2. padrejones2001
    padrejones2001 Puppy Love
    17 Jun 2004
    Sync, as in V-Sync, has nothing to do with resolution. Try a lower refresh rate and it'll probably work a treat.
  3. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    thanks i will attempt it later.
