Case Mod - In Progress Projekt Caelum [Caselabs Mercury S8]
Discussion in 'Project Logs' started by TheXviper, 18 Dec 2014.
  1. TheXviper
    TheXviper What's a Dremel?
    18 Dec 2014
    Update!
    Hello!
    Time for a small update again, it's been a lot of planning the recent week in order to get the wiring as clean as possible, has tested alot and also destroyed some GPU cables so waiting for new ones that I ordered.
    However i have manage to do get some done, I chose to re-draw the tubing around the CPU so I do not need the 90-degree fittings:
    I have also sleeved the CPU cable:
    Then I install three switches to turn off or on my leds in the case, one for the white leds at the top of the case, one for GPU leds and one for the blue leds.
    I also drilled holes for GPU cables through my plexi plate:
    Waiting for my new GPU cables to arrive, then sleeve them. Then it's about time to start up the PC.
  2. GregEl
    GregEl What's a Dremel?
    24 Jan 2015
    Great job! I think it looks better now. Keep it up!
    Shameless plug: If you want to look at another blue and white build you can look at ITX Architecture
    I would also appreciate some feedback.
  3. TheXviper
    18 Dec 2014
    Ty! I agree that it looks way better this way :)
    I will check it out!
  4. TheXviper
    18 Dec 2014
    Update!
    Hello!
    There will be a small update now, the last things for the building has come, so right now i am sleeving the GPU cables and then i will assemble everything.
    Better pictures will come tomorrow if all goes as planned
    But here you get a picture on the GPU cables:
    And a picture of my new SSD:
    More pictures will come tomorrow when i fill the loop.
  5. TheXviper
    18 Dec 2014
    Update!
    Hello!
    Its been i while, i had some trouble with leakage when i filled the loop. I have fixed that now, but i want to re-do some of the tubing so im am waiting for new tube and fittings to arrive.
    I have got some help do make a model in CAD for the backplate:
  6. guitarhero23
    guitarhero23 What's a Dremel?
    27 Mar 2015
    Didn't check out the whole log so unsure if you have a reason for it but you might want to take a look at the bends. They seem a bit wavy. Nice backplate
  7. TheXviper
    18 Dec 2014
    Update!
    Update!
    Its been i while again, but now the project is up anf running again, I got back my custom made backplates today. These should now be painted white. I have also bought ome fittings from Bitspower, including bulkhead.
  8. TheXviper
    18 Dec 2014
    Update!
    Its time for a small update now, I have painted the two backplates white, i am also designing an SLI bridge right now :)
  9. TheXviper
    18 Dec 2014
    Update!
    Hello!
    Now it's time for an update again. HI have finished the last parts in CAD, it is a SLIbridge and a splate that will be mounted on the side of the case. I have also installed two bulkheads in the case. Last but not least I have managed to get over some Bitspower 90 degree fittings, they look awesome so i will use them in my project.
    Some pictures:
    SLIbridge:
    The side:
    The bulkhead:
    The bitspower fittings:
