Projekt: Chieftec
Discussion in 'Project Logs' started by -=Clew=-, 6 Nov 2003.
  1. -=Clew=-
    -=Clew=- What's a Dremel?
    24 Mar 2002
    Hello bit-guys :D
    Well, my english isn't the best, but i'll try the best I can to make you at least understand :rolleyes:
    Well, my first idea was to pick up my old Chieftec Dragon, which i thought was boring, because everybody has it, at least in Sweden...
    So I found some cool mesh and i began to fit it in the front...
    I know you guys love pictures so I'll let the pictures speak for them selves, enjoy them!
    Before it was modded...
    Pieces that had to go to the recycle bin :)
    The standard grilles are gone...
    Made some holes and I began to prepare it for primer..
    The place where the heatcore will be, Rather ugly. but it works ;)
    Just tried some mesh in...
    I use chemical metal (plastic padding stuff) to get the mesh where it should be
    Hrmm, wonder if it would look good this way...
    Project NoFloppy ;)
    Beginning to look like something...
    The Door
    Yes, i'm fixing that gap :).
  2. -=Clew=-
    24 Mar 2002
    Front primered
    Door primered
    Top primered
    Yewk,lots of sctratches..
    Some newly painted 92mm sunons
    Yepp, 2x92mm in the rear
    First layer of paint in the front
    Top painted
    That's all for now...
    And my camera is'nt to good att takings pics.
    The color i lightblue/grey, but looks more like silver on the pics..
    All feedback appriciated!
    Thanks to Pug for the original idea.
  3. Starbuck3733T
    Starbuck3733T Look out sugar, here it comes
    16 Sep 2002
    Pug would be proud! Mesh integration rules! looks good and i'm looking forward to more.
  4. Hallq16
    Hallq16 What's a Dremel?
    30 Aug 2003
    Looks great, cant wait, what will u turn that case into :)
  5. Xgamer
    Xgamer What's a Dremel?
    29 Oct 2003
    nice job on the mesh and painted fans keep it up! :thumb:
  6. Sol Badguy
    Sol Badguy What's a Dremel?
    29 Oct 2003
    nice work..
    now only if i could work with mesh like that :sigh:
  7. noCode
    noCode What's a Dremel?
    16 Oct 2003
    I thought i recognized this.. And there it was "Eskilstuna - Sweden", you have this log at sweclockers.com also, right?
    Looks great man! Where did you got the mesh?
  8. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    I like what you're doing. One little thing... the mesh looks like it is a part you put in yourself later. Maybe try a bit more bondoing and you might make it look like you got it straight from the store like that. :)
  9. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    Great work! :rock:
  10. -=Clew=-
    24 Mar 2002
    Well i have it in swedish on sweclockers.com if someone would be interested :)
    I tried til bondo it a little bit better, but the mesh has so tiny holes so its difficult to get it perfect.
    BTW, the mesh if from an old IKEA (yeah swedish!!!) recycle bin, whick was made of this mesh!
    Thanks for the response!
  11. Snitch
    Snitch Supremodder
    24 Apr 2003
    That looks nice!
    Skitbra faktist!
  12. Pug
    Pug What's a Heatsink?
    16 May 2002
    :rock: Proud as they come, star.
    Good going, Clew. It's a natural mod for the case, you have to agree. :baby:
    I don't envy you with those tiny holes when you clean it up though. Starbuck3733t had a good idea of taping up an edge to keep most of his clean when he did something similar.
    Good luck with filling that gap too, it's really rewarding when you get it just right. :thumb:
    [Edit] Just found out Skitbra means "bloody brilliant". :D :lol:
  13. ngk
    ngk What's a Dremel?
    15 Nov 2003
    i like the mesh look on the front....it's pretty close to perfect...nice work
  14. Gnemelf
    Gnemelf Minimodder
    9 Aug 2003
    looking great. :)
  15. DizBjOhN104
    DizBjOhN104 What's a Dremel?
    3 Nov 2003
    hard work, but keep it up, and you'll reach ur finishing point
