Networks Proper good bluetooth dongle?
Discussion in 'Hardware' started by DragunovHUN, 17 Dec 2017.
  1. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    The antenna wires on my integrated wireless card broke. I tried to source a replacement off ebay but the connectors don't click in place securely so I'm just about ready to give up on that.
    With that in mind, I'm wondering if there's a gold standard USB dongle that'll work at least as good as the Intel AC 7260 or even better.
    I normally use bluetooth to drive my mouse, my keyboard, my gamepad and a nice set of headphones, so pretty much all of my interaction with the PC. Wifi is nice if I don't have to pay much more for it but not a priority at all.
    So, does anyone have a dongle that they really liked or that they knew was reviewed well? Thanks!
  2. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    Not answering your question but have you considered using a tiny dab of hot glue gun glue to hold down the antennas? It’ll hold in place and is generally quite easy to remove still.
  3. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Good call, and a perfect excuse to finally pick up a hot glue gun. I'll probably do it once the machine comes apart again even if I get a dongle.
    I also got some loctite for the threads on the rear IO, the wires broke because those nuts loosened up and allowed the connector to spin. This board is going to be a real bodge job, but good enough to probably get some low wattage chip and turn it into a NAS/CCTV box when I upgrade.
  4. thewelshbrummie
    thewelshbrummie Minimodder
    29 Aug 2009
    I've got an Asus BT-400 USB dongle I'm using in my HTPC via an unbranded USB 3.0 hub - and it works well enough, so long as it has reasonable line of sight with your devices (hence the hub). Originally I'd used it in one of the rear IO USB sockets but had choppy response with my Wedge Keyboard, unless standing over my HTPC with direct line of sight. It's fine for keyboard/mouse use (my MX Anywhere 2 works smoothly without lag). PC World have it for £12.99 if you're interested in it.
  5. sjhujh
    sjhujh Minimodder
    1 Feb 2008
    I bought a Belkin one off amazon it's been reliable so far for me and better than the no name one i had before it....
  6. silk186
    silk186 Derp
    1 Dec 2014
    I've been using an asus dongle for years, it is recommended with a few emulation programs.
