Electronics PS/2 Example Needed
Discussion in 'Modding' started by C0nKer, 4 Jan 2007.
  1. C0nKer
    C0nKer What's a Dremel?
    25 Dec 2005
    Does anyone here got an example of a simple PIC-based PS/2 device that can be used to control the cursor in windows? Circuit(seen a lot) and programming. Just a simple example of the PIC sending data through PS/2 port to the PC to move the cursor, that's all. Nothing more, nothing less.
    PIC -> PS/2 -> PC -> CursorMoves
    And of course, the button presses and all. i googled so hard today to no avail. I found a lot of articles on the protocol but no source codes to allow me to see how it can be implemented.
    Preferably an example in C, Assembly I can look into as well.
    I need it to get started with my project, which is basically to replace a mouse as a pointing device. The pointing method and everything I do my own way, it's just the sending data through the PS/2 that I do not know.
    Thanks in advance.
  2. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    You could always get an older mouse and get the circuit out of that and use the PIC to send "clicks" to the mouse circuit, should be easy enough.
  3. agent420
    agent420 What's a Dremel?
    18 Apr 2006
    I did an AVR touchpad project kind of the other way round, but perhaps some of that info might be helpful to you. There's also a link to my source code in Basic.
    The PS2 protocol documents pretty much contain everything you need, you just have to migrate the described functionality into code.
  4. shotgunefx
    shotgunefx What's a Dremel?
    4 Feb 2004
    There was one online, but now it's gone.
    Try contacting the author via email (panda.cs.ndsu.nodak.edu is what it gave), if you can't reach him, PM me, pretty sure I have a copy of the PIC asm files somewhere.
  5. shotgunefx
    4 Feb 2004
    Found the code, on second thought, it says you can redistribute if you don't change the headers, so here goes.
    Here's the heading from my copy of the page (This totally validates me "Scrapbook"-ing every page of interest, but this was before I had ScrapBook installed)
    Code:
    ;   PS/2 Mouse Emulator by Adam Chapweske (chap0179@tc.umn.edu)                        v1.51
    ;   http://panda.cs.ndsu.nodak.edu/~achapwes/
    ;   This was written for the PIC16F84 with an RC oscillator @ 20pF/5kohm
    ;   (will work with any oscillator between 3.50 MHz - 5.76 MHz)
    ;   FEEL FREE TO USE THIS CODE FOR NON-COMMERCIAL PURPOSES ONLY.  YOU MAY DISTRIBUTE
    ;   THIS CODE ONLY IF IT IS UNMODIFIED FROM ITS ORIGINAL FORM AND IT MUST CONTAIN THIS
    ;   HEADING.  I DO NOT IMPLY ANY WARANTEES OR GUARANTEES.  USE AT YOUR OWN RISK.  ENJOY!!!
    ;   Copyright 2001, Adam Chapweske
    ; CLOCK/TIMING INFORMATION:
    ;   PS/2 bus clock low time =  40 us +/- 25% (30 us - 50 us)
    ;   PS/2 bus clock high time = 40 us +/- 25% (30 us - 50 us)
    ;   RC osc @ 20pF/5k = 4.61 MHz +/- 25% (3.50 MHz - 5.76 MHz)
    ;   1 instruction cycle @ 4.61 MHz (RC) = 0.87 us +/- 25% (0.65 us - 1.09 us)
    ;   Optimum PS/2 bus clock low time @4.61MHz = 45.97 instruction cycles
    ;   Actual PS/2 bus clock low time = 46 instruction cycles
    ;   Actual PS/2 bus clock low time @4.61MHz (RC) = 40.0us +/- 25% (30us-50us)
    ;   Actual PS/2 bus clock frequency @461MHz (RC) = 12.5 kHz +/- 25% (10.0kHz-16.7kHz)
    ;       HEADER:
    		TITLE       "PS/2 Mouse Emulator"
    		SUBTITLE    "Copyright 2001, Adam Chapweske"
    		LIST	    P=16F84
    		INCLUDE	    "p16f84.inc"
                    RADIX       DEC
    		ERRORLEVEL  -224, 1
                    __CONFIG    _CP_OFF & _WDT_OFF & _XT_OSC
    ;	DEFINES:
    #DEFINE	DATA	PORTA, 2	;May be assigned to any I/O pin
    #DEFINE	CLOCK	PORTA, 3	;May be assigned to any I/O pin
    #DEFINE PS2_Yp	PORTB, 0	;May be assigned to any I/O pin
    #DEFINE	PS2_Yn	PORTB, 1	;May be assigned to any I/O pin
    #DEFINE	PS2_Xp	PORTB, 2	;May be assigned to any I/O pin
    #DEFINE	PS2_Xn	PORTB, 3	;May be assigned to any I/O pin
    #DEFINE	PS2_Bl	PORTB, 4	;May be assigned to any I/O pin
    #DEFINE	PS2_Br	PORTB, 5	;May be assigned to any I/O pin
    #DEFINE	PERIOD	20		;Time between reading of inputs.  Min=(osc frequency)/204800
    #DEFINE	DISTANCE 2		;Amount by which X/Y counters are incremented/decremented
    ;	RAM ALLOCATION:
      cblock 0x0C
    	TEMP0, TEMP1
    	RECEIVE, PARITY, COUNTER	;Used in I/O routines
    	REPORT_RATE, RESOLUTION		;Used for responses to status requests
    	FLAGS, XY_FLAGS
    	dBUTTONS			;"Delta Button States"
    	X_COUNTER
    	Y_COUNTER
      endc
    ;FLAGS:
    ; bit 7 -- Always 0
    ; bit 6 -- Stream(0)/Remote(1) mode
    ; bit 5 -- Disable(0)/Enable(1) reporting
    ; bit 4 -- 1:1(0)/2:1(1) Scaling
    ; bit 3 -- Always 0
    ; bit 2 -- Always 0
    ; bit 1 -- Always 0
    ; bit 0 -- Always 0
    MODE	equ	6
    ENABLE	equ	5
    SCALE	equ	4
    ;XY_FLAGS:
    ; bit 7 -- Y Counter overflow
    ; bit 6 -- X Counter overflow
    ; bit 5 -- Y counter sign bit
    ; bit 4 -- X counter sign bit
    ; bit 3 -- Always 1
    ; bit 2 -- Always 0 (middle button)
    ; bit 1 -- Previous right button state
    ; bit 0 -- Previous left button state
    yOVF	equ	7
    xOVF	equ	6
    ySIGN	equ	5
    xSIGN	equ	4
    ;dBUTTONS
    ; bit 7 -- Always 0
    ; bit 6 -- Always 0
    ; bit 5 -- Always 0
    ; bit 4 -- Always 0
    ; bit 3 -- Always 0
    ; bit 2 -- Always 0
    ; bit 1 -- Change in right buton state
    ; bit 0 -- Change in left button state
      cblock		;Contains to-be-sent packet and last packet sent
    	LENGTH
    	SEND1
    	SEND2
    	SEND3
      endc
    ;       MACROS:
    ;Delay "Cycles" instruction cycles
    Delay		macro	Time
      if (Time==1)
    		nop
      		exitm
      endif
      if (Time==2)
    		goto	$ + 1
    		exitm
      endif
      if (Time==3)
    		nop
    		goto	$ + 1
    		exitm
      endif
      if (Time==4)
    		goto	$ + 1
    		goto	$ + 1
    		exitm
      endif
      if (Time==5)
    		goto	$ + 1
    		goto	$ + 1
    		nop
    		exitm
      endif
      if (Time==6)
    		goto	$ + 1
    		goto	$ + 1
    		goto	$ + 1
    		exitm
      endif
      if (Time==7)
    		goto	$ + 1
    		goto	$ + 1
    		goto	$ + 1
    		nop
    		exitm
      endif
      if (Time%4==0)
    		movlw	(Time-4)/4
    		call	Delay_us
    		exitm
      endif
      if (Time%4==1)
    		movlw	(Time-5)/4
    		call	Delay_us
    		nop
    		exitm
      endif
      if (Time%4==2)
    		movlw	(Time-6)/4
    		call	Delay_us
    		goto	$ + 1
    		exitm
      endif
      if (Time%4==3)
    		movlw	(Time-7)/4
    		call	Delay_us
    		goto	$ + 1
    		nop
    		exitm
      endif
    		endm
    ;       ORG 0x000:
    		org	0x000
    		goto	Start
    ;	HANDLE COMMAND:
      if (high Table1End != 0)
    		ERROR	"Command handler table must be in low memory page"
      endif
    Command		movlw	0x04		;Test for a resolution value
    		subwf	RECEIVE, w
    		bnc	SetResolution
    		movlw	0xC8		;Test for report rate value
    		subwf	RECEIVE, w
    		bnc	SetReportRate
    		movlw	0xE6		;0xE6 is lowest code
    		subwf	RECEIVE, w
    		bnc	MainLoop
    HandlerTable	addwf	PCL, f		;Add offset
    		goto	Mouse_E6	;0xE6 - Set Scaling 1:1
    		goto	Mouse_E7	;0xE7 - Set Scaling 2:1
    		goto	MainLoop	;0xE8 - Set Resolution
    		goto	Mouse_E9	;0xE9 - Status Request
    		goto	Mouse_EA	;0xEA - Set Stream Mode
    		goto	Report		;0xEB - Read Data
    		goto	MainLoop	;0xEC - Reset Wrap Mode
    		goto	MainLoop	;0xED -
    		goto	WrapMode	;0xEE - Set Wrap Mode
    		goto	MainLoop	;0xEF
    		goto	Mouse_F0	;0xF0 - Set Remote Mode
    		goto	MainLoop	;0xF1
    		goto	Mouse_F2	;0xF2 - Read Device Type
    		goto	MainLoop	;0xF3 - Set Report Rate
    		goto	Mouse_F4	;0xF4 - Enable
    		goto	Mouse_F5	;0xF5 - Disable
    		goto	Mouse_F6	;0xF6 - Set Default
    		goto	MainLoop	;0xF7
    		goto	MainLoop	;0xF8
    		goto	MainLoop	;0xF9
    		goto	MainLoop	;0xFA
    		goto	MainLoop	;0xFB
    		goto	MainLoop	;0xFC
    		goto	MainLoop	;0xFD
    		goto	PacketOut	;0xFE - Resend
    Table1End	goto	Reset		;0xFF - Reset
    ;	START:
    Start		clrf	PORTA
    		clrf	PORTB
    		bsf	STATUS, RP0	;(TRISA=TRISB=0xFF by default)
    		movlw	0x57		;Timer mode, assign max. prescaler, enable pullups
    		movwf	OPTION_REG
    		bcf	STATUS, RP0
    		movlw	0x08		;Bit 3 always = 1, clear previous button states
    		movwf	XY_FLAGS
    ;		goto	Reset
    ;       Reset Mode:
    Reset		movlw	0xAA
    		movwf	SEND1		;Load BAT completion code
    		call	LoadDefaults
    		clrf	SEND2		;Load Device ID (0x00)
    		movlw	0x02
    		movwf	LENGTH
    		call	BATdelay
    		goto	PacketOut	;Output 2-byte "completion-code, device ID" packet
    ;       Stream/Remote Mode:
    MainLoop	clrf	X_COUNTER	;Clear movement counters
    		clrf	Y_COUNTER
    MainLoop1	btfss	DATA		;Check for host request-to-send
    		goto	PacketIn
    		movlw	PERIOD		;Report period
    		subwf	TMR0, w
    		btfss	STATUS, C	;TMR0=report period?
    		goto	MainLoop1	;  No--loop
    		clrf	TMR0		;  Yes--reset TMR0, then read inputs...
    		call	ReadInputs
    		btfsc	FLAGS, MODE	;Stream(0)/Remote(1) mode
    		goto	MainLoop1
    		btfss	FLAGS, ENABLE	;Disable(0)/Enable(1) reporting
    		goto	MainLoop1
    		movf	X_COUNTER, w	;Test for X-movement
    		iorwf	Y_COUNTER, w	;Test for Y-movement
    		iorwf	dBUTTONS, w	;Test for change in button states
    		bz	MainLoop1
    ;		goto	Report
    ;	REPORT:
    Report		movf	dBUTTONS, w
    		xorwf	XY_FLAGS, f	;Find current button state
    		movf	XY_FLAGS, w
    		movwf	SEND1
    		movf	X_COUNTER, w
    		movwf	SEND2
    		movf	Y_COUNTER, w
    		movwf	SEND3
    		movlw	0x03		;Movement data report length
    		movwf	LENGTH
    ;		goto	PacketOut
    ;	OUTPUT PACKET
    PacketOut	movlw	SEND1		;First byte of packet
    		movwf	FSR
    		movf	LENGTH, w	;Length of packet
    		movwf	TEMP1
    PacketOutLoop	movf	INDF, w		;Get data byte
    		call	ByteOut		;  Output that byte
    		xorlw	0xFF		;Test for RTS error
    		bz	PacketIn
    		xorlw	0xFE ^ 0xFF	;Test for inhibit error
    		bz	PacketOut
    		incf	FSR, f		;Point to next byte
    		decfsz	TEMP1, f
    		goto	PacketOutLoop
    		goto	MainLoop
    ;	READ PACKET
    PacketIn	call	ByteIn
    		xorlw	0xFF		;Test for parity/framing error
    		bz	Mouse_ERR
    		bz	MainLoop1
    		movlw	0xFE		;Test for "Resend" command
    		xorwf	RECEIVE, w
    		bz	PacketOut
    Acknowledge	movlw	0xFA		;Acknowledge
    		call	ByteOut
    		goto	Command
    ;	READ INPUTS:
    ReadInputs	movlw	DISTANCE
    		btfss	PS2_Xp		;Read inputs
    		addwf	X_COUNTER, f
    		btfss	PS2_Yp
    		addwf	Y_COUNTER, f
    		btfss	PS2_Xn
    		subwf	X_COUNTER, f
    		btfss	PS2_Yn
    		subwf	Y_COUNTER, f
    		bcf	XY_FLAGS, xSIGN
    		btfsc	X_COUNTER, 7
    		bsf	XY_FLAGS, xSIGN
    		bcf	XY_FLAGS, ySIGN
    		btfsc	Y_COUNTER, 7
    		bsf	XY_FLAGS, ySIGN
    		movf	XY_FLAGS, w	;Get previous button states
    		andlw	b'00000111'
    		btfss	PS2_Bl		;Find changes in button states
    		xorlw	b'00000001'
    		btfss	PS2_Br
    		xorlw	b'00000010'
    		movwf	dBUTTONS	;Save *change* in button state
    		retlw	0x00
    ;	WRAP MODE:
    WrapMode	btfsc	DATA		;Wait for RTS
    		goto	WrapMode
    		call	ByteIn		;Read one byte from host
    		xorlw	0xFE		;Test for aborted transmission
    		bz	WrapMode
    		movf	RECEIVE, w
    		xorlw	0xFF		;Test for "Reset" command
    		bz	Acknowledge
    		xorlw	0xFF^0xEC	;Test for "Reset Wrap Mode" command
    		bz	Acknowledge
    		xorlw	0xEC
    		call	ByteOut		;Else, echo
    		goto	WrapMode
    ;	LOAD DEFAULT VALUES:
    LoadDefaults	movlw	100		;Default report rate
    		movwf	REPORT_RATE
    		movlw	0x02		;Default resolution
    		movwf	RESOLUTION
    		clrf	FLAGS		;Stream mode, 1:1 scaling, disabled
    		retlw	0x00
    ;	EMULATE BAT:
    BATdelay	clrf	TEMP0		;Used for a 400 ms delay at power-on
    		clrf	TEMP1
    DelayLoop	Delay	6
    		decfsz	TEMP0, f
    		goto	DelayLoop
    		decfsz	TEMP1, f
    		goto	DelayLoop
    		retlw	0x00
    ;	HANDLE COMMANDS:
    SetResolution	movf	RECEIVE, w
    		movwf	RESOLUTION
    		goto	MainLoop
    SetReportRate	movf	RECEIVE, w
    		movwf	REPORT_RATE
    		goto	MainLoop
    Mouse_E6	bcf	FLAGS, SCALE
    		goto	MainLoop
    Mouse_E7	bsf	FLAGS, SCALE
    		goto	MainLoop
    Mouse_E9	movf	FLAGS, w
    		btfss	PS2_Bl
    		iorlw	0x04
    		btfss	PS2_Br
    		iorlw	0x01
    		movwf	SEND1
    		movf	RESOLUTION, w
    		movwf	SEND2
    		movf	REPORT_RATE, w
    		movwf	SEND3
    		movlw	0x03
    		movwf	LENGTH
    		goto	PacketOut
    Mouse_EA	bcf	FLAGS, MODE
    		goto	MainLoop
    Mouse_F0	bsf	FLAGS, MODE
    		goto	MainLoop
    ;0xF2 - Get Device ID
    Mouse_F2	clrf	SEND1
    		movlw	0x01
    		movwf	LENGTH
    		goto	PacketOut
    ;0xF4 - Enable Reporting
    Mouse_F4	bsf	FLAGS, ENABLE
    		goto	MainLoop
    ;0xF5 - Disable Reporting
    Mouse_F5	bcf	FLAGS, ENABLE
    		goto	MainLoop
    ;0xF6 - Set Default
    Mouse_F6	call	LoadDefaults
    		goto	MainLoop
    ;Invalid command
    Mouse_ERR	movlw	0xFE
    		call	ByteOut
    		goto	MainLoop
    ;	OUTPUT ONE BYTE:  - TIMING IS CRITICAL!!!
    ByteOut		movwf	TEMP0
    InhibitLoop	btfss	CLOCK		;Test for inhibit
    		goto	InhibitLoop
    		Delay	100		;(50 microsec = 58 clock cycles, min)
    		btfss	CLOCK
    		goto	InhibitLoop
    		btfss	DATA		;Check for request-to-send
    		retlw	0xFF
    		clrf	PARITY
    		movlw	0x08
    		movwf	COUNTER
    		movlw	0x00
    		call	BitOut		;Start bit (0)
    		goto	ByteOutEnd
    		Delay	4
    ByteOutLoop	movf	TEMP0, w
    		xorwf	PARITY, f
    		call	BitOut		;Data bits
    		goto	ByteOutEnd
    		rrf	TEMP0, f
    		decfsz	COUNTER, f
    		goto	ByteOutLoop
    		Delay	2
    		comf	PARITY, w
    		call	BitOut		;Parity bit
    		goto	ByteOutEnd
    		Delay	5
    		movlw	0xFF
    		call	BitOut		;Stop bit (1)
    		Delay	48
    		retlw	0x00
    ByteOutEnd	bsf	STATUS, RP0
    		bsf	DATA
    		bsf	CLOCK
    		bcf	STATUS, RP0
    		retlw	0xFE
    BitOut		bsf	STATUS, RP0
    		andlw	0x01
    		btfss	STATUS, Z
    		bsf	DATA
    		btfsc	STATUS, Z
    		bcf	DATA
    		Delay	21
    		bcf	CLOCK
    		Delay	45
    		bsf	CLOCK
    		bcf	STATUS, RP0
    		Delay	5
    		return
    ;	READ ONE BYTE: (Takes about 1ms) - TIMING IS CRITICAL!!!
    ByteIn		btfss	CLOCK		;Test for Request-to-send
    		retlw	0xFE
    		btfsc	DATA
    		retlw	0xFE
    		movlw	0x08
    		movwf	COUNTER
    		clrf	PARITY
    		Delay	28
    ByteInLoop	call	BitIn		;Data bits
    		retlw	0xFE
    		bcf	STATUS, C
    		rrf	RECEIVE, f
    		iorwf	RECEIVE, f
    		xorwf	PARITY,f
    		decfsz	COUNTER, f
    		goto	ByteInLoop
    		Delay	1
    		call	BitIn		;Parity bit
    		retlw	0xFE
    		xorwf	PARITY, f
    		Delay	5
    ByteInLoop1	Delay	1
    		call	BitIn		;Stop bit
    		retlw	0xFE
    		xorlw	0x00
    		btfsc	STATUS, Z
    		clrf	PARITY
    		btfsc	STATUS, Z	;Stop bit = 1?
    		goto	ByteInLoop1	;  No--keep clocking.
    		bsf	STATUS, RP0	;Acknowledge
    		bcf	DATA
    		Delay	11
    		bcf	CLOCK
    		Delay	45
    		bsf	CLOCK
    		Delay	7
    		bsf	DATA
    		bcf	STATUS, RP0
    		btfss	PARITY, 7	;Parity correct?
    		retlw	0xFF		;  No--return error
    		Delay	45
    		retlw	0x00
    BitIn		Delay	8
    		bsf	STATUS, RP0
    		bcf	CLOCK
    		Delay	45
    		bsf	CLOCK
    		bcf	STATUS, RP0
    		Delay	21
    		btfsc	DATA
    		retlw	0x80
    		retlw	0x00
    ;	DELAY:
    ;Delays 4w+4 cycles (including call,return, and movlw) (0=256)
    Delay_us	addlw	-1  		;Precise delays used in I/O
    		btfss	STATUS, Z
    		goto	Delay_us
    		return
    		end
  6. shotgunefx
    4 Feb 2004
  7. C0nKer
    25 Dec 2005
    Thanks for the help guys.
    agent420 for reference to your AVR Pad
    shotgunefx for the source code and schematic of a PIC based mouse.
    r4tch3t for a rather interesting idea. Maybe I should consider that if all else fails. At least for demonstration purposes :D .
  8. shotgunefx
    4 Feb 2004
    No problem.
    agent420, nice project, got a few of them lying around here, have to give it a whirl.
  9. agent420
    18 Apr 2006
    :hip: Thanks
  10. Macaba
    Macaba What's a Dremel?
    4 Mar 2006
  11. shotgunefx
    4 Feb 2004
    Glad to know the code works, haven't gotten around to building one yet. :)
  12. amuntianu
    amuntianu What's a Dremel?
    18 Jan 2007
    Macaba could you post the assembler code that you modified for your project ? Pls
  13. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    groovygamegear.com has some great interface devices for good prices. I keep looking at it and thinking of making my own game controller.
  14. C0nKer
    25 Dec 2005
    This might have come a bit too late, but i finally get to work on making my own air mouse.
    I stumble upon a brick wall when in PS/2 part.
    This is my PS/2 line analysis, debugging program of some sort. The PIC reports every transaction that occurs on the line, successful send, successful receive, parity/stopbit error or any inhibition during transfer. considering i see the data being sent and received is the same as described by the documentation, I think the initialization part is a bit on the successful side........
    ..... other than the host PC (in this case a laptop) keeps hogging the line and spams 0x10 to the PIC, preventing it from reporting movement packet when it is allowed to as indicated by host sending 0xF4 and the PIC replying 0xFA right before the 0x10 spamming.
    Other commands from host PC that I don't know how to respond to. I see these sometimes but, they don't pop up as often.
    0xFA <--- i thought the PIC is suppose to be the one sending this ack byte, not receiving the ack byte
    0xEC <--- suppose to be when mouse in wrap mode, but wrap mode command (0xEE) never came in the first place
    0xED <--- came after i reply 0xFA to command 0xEC above, i just simply added the ack to test it out. 0xED came after 0xEC
    any further help greatly appreciated
