Other PS3 Problem
Discussion in 'Tech Support' started by kol, 27 Oct 2012.
  1. kol
    kol What's a Dremel?
    31 May 2011
    So i decided it was time to clean out the ps3, i opened it up cleaned it all out put it back together, switched it on, put a game in, needed an update, half way through the ps3 turned itself off. Now it wont turn back on, anyone got any ideas why?
    Mobo short? Psu blown?
    Its a 60GB version, cheers.
    Sent from my Nexus 7 using Tapatalk 2
  2. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    No red blinking light at the front? If not I would say it's either the PSU or something overheated.
  3. noizdaemon666
    15 Jun 2010
  4. kol
    31 May 2011
    Was thinking psu, but just read that the eject/on ribbon cable might be the problem. When i have the power cable plugged in and turned on i hear a soft clicking noise so i know there is power.
  5. CoffeeTwoSugars
    CoffeeTwoSugars What's a Dremel?
    9 Jan 2012
    I had this problem, and it turned out the HDD connection was loose all it took was a reattachment, hope this helps
