Playstation 3 PS3 set up... HELP NEEDED!!
Discussion in 'Gaming' started by 666painkiller, 5 Aug 2010.
  1. 666painkiller
    666painkiller If only....
    23 Jun 2010
    Can anyone help me with my PS3 set up?
    My PS3 and pc use the same monitor-a LG W2261V-PF 22" Widescreen Flatron Full HD LCD
    http://www.lg.com/uk/it-products/monitors/LG-lcd-monitor-W2261V.jsp
    The speakers i use are Creative Inspire T6100
    http://uk.creative.com/products/pro...ory=924&subcategory=928&product=15774&listby=
    Connected to a Sound Blaster X-Fi Xtreme Gamer on my pc
    http://uk.store.creative.com/products/product.aspx?catid=1&pid=15853
    Now my question...at the moment my PS3 sound is via headphones connected to my monitor(PS3 conects via HDMI)...is there anyway I can use my speakers for PS3 and pc?
    PLEASE HELP!!!:duh:
  2. shigllgetcha
    shigllgetcha Minimodder
    3 Mar 2008
    what do you call the normal non hdmi cable with the three connections on the end, yellow white and red
    can you connect this and the hdmi at the same time and run the sound through the non hd cable and connect to your speakers?
  3. malikdrako
    malikdrako Minimodder
    27 Sep 2006
  4. Plugs
    Plugs Minimodder
    5 Nov 2009
    I have a similar monitor
    i have my setup as follows
    PS3 -> HDMI-> Monitor -> 3mm jack cable (line in)-> PC -> 3mm jack cable (line out) to speakers
    requires me to have my pc on whilst using my PS3, but i would have it on anyway
    works perfectly
  5. ilikesimple
    ilikesimple AKA Scare100
    9 Jun 2010
    DO you have more than one input for your speakers?
    If so then why don't you just plug the monitor port into the speakers.
    Or if your speakers support Optical in then use the Optical out at the back of the PS3
  6. lcdguy
    lcdguy Minimodder
    25 May 2004
    i had mine setup like this. Also my speakers have an auxiliary input.
    PS3 -> Monitor (HDMI->DVI)
    PS3 Audio -> Speakers
    Computer -> Speakers
    The audio connections are analgoue but that's not a huge concern of mine.
