*edit* I just notice "Electronics" category....Admin/Moderator if this thread belong to there please move it to there....sorry MBM detected my -12.00 @ -7.26 and -5.00 @ +0.38 what is the wrong with my board!!! currently using AMD XP 2200+ Cooler Master Aero 7+ Abit KX7-Raid WD 80GB JB PowerColor ATI 9000 128mb Creative Adigy Pixelview TV Tuner D-Link 538TX 2x EverCool 120mm (EC12025M12S) DC 12V 0.38A 4.56W Enlight 420 (spec ) can someone please tell me what is happening?
Sounds like you got a short somewhere. If your 5 and -12 got mixed up, you'd have 7. And if your -5 got mixed with...umm...your +5, you'd have 0 or close to it. Are you sure you didn't take a bundle of random wires from your PSU and soldered them together? EDIT: Either that, or your mobo's voltage reporting sucks. It might not actually be those numbers.
There's nothing wrong with your system, ignore MBM on negative voltages and don't spend any money on the strength of any other readings. If the box runs stable, it's OK.
My -5 and -12 are the same... reported as +2.3 and -1.2 respectively... as metioned if its stable then its fine, +5/12 are ok so no need to worry
MBM can't read - voltages for crap. according to MBM my -12 is -10 and my -5 is -6 and its says my +5 is at +4 and ASUS PCprobe reads 5.04V
I'm using the same mobo as yours too Highland3r btw what probe are you using for your Abit KX7-Raid board? Yup its working fine. Not causing any prob at the moment. What processor are you using? Cuz I'm using 2200+ and want to try overclocking. Will post the cpu code ltr. I have asked you about your temp before cuz we both are using Aero 7+
