PSU PSU cable query
Discussion in 'Hardware' started by Xaine, 29 Sep 2014.
  1. Xaine
    Xaine Death... destroyer of brain cells
    19 Sep 2012
    This may seem like a stupid question but it seems best to be certain.
    Just received my sexy new MSI GTX 970, it requires a 6-pin and an 8-pin power connection, my PSU (HX850i) has 3 cables each with 2x6+2-pin PCI E connections, am I right in thinking its ok to usejust one cable with both of the connections for the GPU, only reason I ask is as it from the same cable it seems like a single 8 pin could provide the same power if its on the same cable?
    Help asap would be grand as I'm getting anxious to plug this bad boy in.
    Regards
    Mike
  2. MeddlE
    MeddlE Norwegian Blue
    23 May 2011
    Technically you can but I personally wouldn't. Spread the load over two cable runs.
  3. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Single cable run will be fine.
    That PSU is designed with a Multi-GPU setup in mind! :thumb:
  4. Xaine
    19 Sep 2012
    Cheers guys, appreciate the info
  5. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    yeap, its a 70A single rail psu, so you will get away with using a single cable (so long as the conductors are suitable)
