Electronics PSU connector part numbers
Discussion in 'Modding' started by Hazer, 18 Sep 2004.
  1. Hazer
    Hazer In time,you too will be relixalated
    14 Apr 2003
    Have you wanted to get just the plugs and pins for your standard ATX PSU?
    Sick of looking endlessly?
    Well, Ive got nothing better to do on a Friday night, so here you go:
    Included are the ordering numbers from Mouser since they sell most of this in single peices.
    HDD connectors (basic 4 pin stuff):
    Male receptacle (whats on the PSU cable, although pins are female)
    Molex 8981-04P
    AMP 1-480424
    Mouser PN 571-14804240
    Panel mount Male receptacle
    Mouser PN 571-14804250
    Pins for Male receptacles
    Mouser PN 571-606191
    Female housing (panel or free, device end)
    Mouser PN 571-14804260
    PCB housing (device end)
    Mouser PN 571-3502111
    Pins for Female housings
    Mouser PN 571-606201
    90 degree in-line receptacles (cable end, no back cover)
    Mouser PN 571-770156X (3 colors)
    20 pin ATX Main connector
    Receptacle (cable end)
    Molex 39-01-2200
    Mouser PN 571-2794954-0
    Pins for receptacle
    Mouser PN 571- 15863151
    PCB header
    Mouser PN 571-215860370
    Free header
    Mouser PN 571-215860000
    Panel mounter header
    Mouser PN 571-27949530
    Pins for header
    Mouser PN 571-15863141
    ATX 12V AUX 4pin connector
    4 pin receptacle (cable end)
    Molex 39-01-2040
    Mouser PN 571-7949544
    Pins for receptacle
    Mouser PN 571-15863151
    Free header
    Mouser PN 571-15860004
    Panel header
    Mouser PN 571-7949534
    PCB header
    Mouser PN 571-15860374
    Pins for headers
    Floppy drive connector
    AMP 171822-4
    Aux 6pin power connector
    Molex 90331-XX10
    Mouser has these plugs for like 20 cents each. You can order as many (or as little) as you wish, but get the pins too. Dunno how many people care about this stuff, but I certainly value it. :geek:
  2. Starbuck3733T
    Starbuck3733T Look out sugar, here it comes
    16 Sep 2002
  3. warmonger
    warmonger What's a Dremel?
    20 Apr 2002
    I recently spent a while looking for SATA power connectors, so I figured I would share the info with anyone else that might need it.
    Female Receptacle, 180 degree: (requires pins below)
    Molex P/N: 67582-0000
    Pin for 180 degree receptacle above: (need 5 per receptacle)
    Molex P/N: 67581-0010
    Molex P/N: 67581-0011
    Molex P/N: 67581-0012
    (The only difference is plating thickness, any of these pins would work for most people)
    Female Receptacle, 90 degree: (requires back-piece below)
    Molex P/N: 67926-0011
    Female Receptacle, 90 degree, with latch: (requires back-piece below)
    Molex P/N: 67926-0001
    Pass-Through back-piece for 90 degree receptacles above:
    Molex P/N: 67926-0041
    Feed-To back-piece for 90 degree receptacles above:
    Molex P/N: 67926-0040
  4. landspeeder95
    landspeeder95 What's a Dremel?
    11 May 2010
    thank you
  5. NavidsonRecord
    NavidsonRecord Where the bloody hell are ya'?
    5 Jan 2010
    really helpfull thank you
  6. politeNovice
    politeNovice What's a Dremel?
    27 Feb 2012
    @Hazer, @starbuck3733T, @warmonger..........Thank you very much, I am going to wade through all this information and see if perhaps I can find exactly What I am looking for!
    ....it looks as though the male connector pin from molex,#02081236(male pin) is classified obsolete. I see that many of the peripheral(male-pin) housing receptacles that are manufactured by molex are classified as "wire to board". The only wire to wire male-housing receptacle is from mate'n'lock by TE: http://www.te.com/catalog/pn/en/1-480426-0#features
    I would think that it would be silly that nobody manufactures and sells the male version of Molex#0002081202....and I mean in a way which is completely separate from any type of Receptacle housing....
    In any event, Your fine responses may contain the solution I need, so thanks again, and I shall get busy here.
    And FYI to any other newbies out here...when you order your connectors...some model numbers differ based on the way they are packaged. And unless you want to buy tens of thousands at a time, look for connectors which are sold in bags rather than reels, because they usually seem not to have a minimum # per order.
    Thanks again!
    PoliteNovice
    -PoliteNovice
  7. politeNovice
    27 Feb 2012
    Wonderful, Yes this was helpful to me! I was looking for a good way to order both parts, Mouser PN: 60619-1 and 60620-1. I don't even have to order a thousand at a time! whew!
    I hope that this information will remain available to other folks like myself, who may find great use of it at times.
    Have a great day,
    PoliteNovice
