Build Advice psu / cpu power / gpu power question
Discussion in 'Hardware' started by stephen0205, 12 Sep 2021.
  1. stephen0205
    stephen0205 MrSteve
    11 Mar 2016
    So im having a brain fart moment, and telling myself it will be fine. But wanted to double check
    Old intel 3770k system
    Bought this psu to go in it, the 8 pin cable dont reach the cpu power, im right in reading that i will just need to buy an 8pin to 8 pin extender ? (im not gonna cut them and do it myself as its for my nephew)
    https://www.newegg.com/seasonic-s12-ss-430hb-ob-430w/p/N82E16817151044
    And for the gpu picked up this on here recently, which is an 8 pin, i have an adapter which is 2 6 pin to one 8 pin ...... would that work ?, it says it needs 450 wats but only draws like 120 ish so should be fine ? , or would i be better with just a 6 pin to 8 pin adapter to conquer it ?
    https://www.bhphotovideo.com/c/prod...v_rx570gaming_4gd_radeon_rx_570_4g.html/specs
  2. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    I would have thought a single 6-pin to 8-pin would do the job just fine.
    I would also think that the PSU would be enough, just don't try overclocking.
  3. Stanley Lopez
    Stanley Lopez What's a Dremel?
    15 Sep 2021
    Why to wanna try overclocking? Is there any specific reason i want to know.
  4. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Overclocking will significantly increase the power draw potentially. So it could end up over the rated maximum for the PSU.
  5. stephen0205
    stephen0205 MrSteve
    11 Mar 2016
    thanking you fellas, i wont be overlocking it, maybe down the line when its on its last legs lol, its for my nephew so as i need to touch as less stuff as possible so it runs without tweaking here and there when things dont work, i wont be monitoring it like i do my own machine so gonna be fairly maintance free
