PSU PSU crackling
Discussion in 'Hardware' started by dipzy, 19 Jun 2014.
  1. dipzy
    dipzy Active Member
    5 Jan 2013
    Hi guys,
    i have a Silverstone ST-1500 PSU. I seem to get static like crackling noise from it. It only happens when playing games.
    When playing movies or just browsing the net, all is fine
    It doesn't sound normal but can this sort of thing happen on load?
    :eeek:
  2. Impatience
    Impatience Well-Known Member
    6 Apr 2014
    I would get it RMA'd ASAP! Any static buildup in a PSU is baaad news IMO, especially since electricity can and will arc across ppcb traces if enough static is present, potentially blowing it!
  3. RagingMadman
    RagingMadman New Member
    6 Oct 2012
    That sounds like bad mojo man.
    It's understandable you only hear it when gaming as this is when the psu would most likely be under load. I 2nd the RMA suggestion as there isn't much you can do to a PSU without voiding the warranty.
  4. veryevil
    veryevil Well-Known Member
    14 Aug 2005
    sure its not the mains cable loose round back?
  5. dipzy
    dipzy Active Member
    5 Jan 2013
    At first i thought it was my STX sound card then i opened my case door and put my head right inside the case and heard it was the psu.
    This will be my 2nd RMA with silverstone as the first one had a terrible crackling and lighting sparks from the fan. If it does get approved then it will also be my 3rd Silverstone PSU :(
    Here's the Video in case you guys want to hear it: Link
  6. dipzy
    dipzy Active Member
    5 Jan 2013
    Nope, i checked this, pushed all the way in PSU, not loose at all
