PSU PSU for CF 7970 (non ghz)?
Discussion in 'Hardware' started by docodine, 30 Dec 2012.
  1. docodine
    docodine killed a guy once
    10 Feb 2007
    I just got a great deal on a pair of used 7970s locally, and was wondering if my PSU was up to the task.. I'm guessing no.
    Any reasonably priced recommendations? IDC about whether it's modular or not
    Was looking at this discounted (and fairly old) Kingwin unit, Super Flower OEM
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817121070
    I could even just get a second PSU, my TJ07 has two bays... Anyone have experience with an Add2Psu or similar product? I could just pick up a second TX650V2 and call it a day
  2. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
  3. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
  4. docodine
    10 Feb 2007
    sorry if i wasn't clear, was looking more for model recommendations
    don't have any use for a power calculator, i know that i'll need ~850W
  5. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    Anything from a reputable brand will fit the bill. Really depends how much you want to spend / what features you want. Normally you pay a bit extra for semi / full modular and the higher the efficiency ratings (bronze, silver, gold, platinum) the greater the cost. Can't comment on prices for scan and such but a lot of the community will recommend brands such as seasonic, corsair, enermax, coolermaster, etc.
  6. IvanIvanovich
    31 Aug 2008
    What I would get, Seasonic X850
    But judging from you had in the first post I suspect you might be looking for something cheaper so maybe the SS850AM instead?
    I defineatly wouldn't skimp on some cheap psu for some nice hardware.
  7. docodine
    10 Feb 2007
